new rubber for doors
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by kiley, Apr 25, 2001.
  1. kiley
    kiley Registered Member
    Mar 5, 2001
    87
    Salem, Oregon
    Has anyone installed new weatherstripping around the doors? I just spent $200 at Chevyduty and I'm not that happy with the fit. Any suggestions as to what needs to be done to "break in" new weatherstripping?
  2. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    What's the problem with the weatherstripping? Is it too thick or causing trouble closing the doors?
    Does it still have air gaps? Is the material just very stiff?
    -Greg72
  3. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Wierd. The weatherstripping I got for my Blazer was from Chevy Duty too and it fit really nice. It was difficult to close the doors initially because the original door gaskets were shot and/or missing (and it seems that someone adjusted the doors for the dead/missing gaskets). They were just fine after readjusting the doors a little and letting the gaskets soften in the sun a little.
  4. kiley
    Mar 5, 2001
    87
    Salem, Oregon
    The rubber seems too thick where the windshield meets the top of the door and the roof. Not sure if that made any sense. I had to really fight to get the top screwed back in. The top to window seals are fine exept where the door meets the top just behing the door lock. It's where you actually screw the rubber into the top. The thick part is just too tall. Instead of the window resting against the rubber it is forcesthe rubber to roll in. It actually tore a little and is getting worse each time I close the door. I will say that the passenger side is shutting better than the drivers side and after thinking about it the drivers side door does sag just a touch.
  5. kiley
    Mar 5, 2001
    87
    Salem, Oregon
    How do you adjust the doors?
    P. S. thanks to you both for responding, much appreciated.
  6. Steve_Chin
    Mar 6, 2001
    1,126
    The holes for the mounting bolts on the hinges, doors, and body are over-sized and allow you to adjust the lateral, vertical, and longitudinal position and angle of the doors.
  7. kiley
    Mar 5, 2001
    87
    Salem, Oregon
    I meant to thank you again for the info. The rubber has settled in a little and things fit better. I haven't tried to adjust the doors yet. The passenger side is actually pretty great although water leaks in through the rubber drip rails worse than the old ones did. The drivers side window cannot be rolled up unless the door is open. The glass "wants" to roll up behind the rubber instead of seating in front of it. The top is off for summer now so adjustments will have to wait!
    72 cst http://www.kiley.coloradok5.com
