New SAS Spring Hangers
Discussion in '1992-Present Chevy & GMC models' started by Eastcoast 4WD, Jul 13, 2006.
  1. Eastcoast 4WD
    Eastcoast 4WD Registered Member
    Jan 6, 2006
    45
    Northeast PA
    We are going to begin making SAS leaf spring hangers for IFS truck due to the demand for a quality product at a reasonable price. From most of the threads I've read most people's opinion is that the ORU Brackets are on the expensive side. We will be starting with th 32" width brackets first b/c that will fit the most axle models. I am looking for the following input from you guys:
    1. What do you want to see included in the kit? Shock Mounts, Spring
    Plates, Bump Stop Mounts ?
    2. Does in need to be a kit or would you rather have just the Hangers?
    3. What distance between the brackets to achieve proper shackle angle?
    It seems that many of you who used the ORU kit were not happy with
    Angle they built in.
    4. Bolt on or Wled on? Or a kit for each?
    5. Price? What would be a reasonable price so that most of you guys would
    say "It's not worth my time trying to make them my self"
    We look foward to your feed back.
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I don't plan on doing a SAS anytime soon, but 2 of my friends recently installed them. One was an ORU on a '96 Z71 and the other was a Fabritech on an '03 2500HD. I can offer some suggestions (in red print) from their complaints.
    Originally Posted by Eastcoast 4WD
    We are going to begin making SAS leaf spring hangers for IFS truck due to the demand for a quality product at a reasonable price. From most of the threads I've read most people's opinion is that the ORU Brackets are on the expensive side. Yes, WAY overpriced. We will be starting with th 32" width brackets first b/c that will fit the more axle models. I am looking for the following input from you guys:
    Plates, Bump Stop Mounts ? A trac-bar would be nice. When sitting still and turning the steering wheel, the ORU shackles flex left/right over an inch because the crossover steering is pushing the truck to the side as the tie rod tries to turn the wheels. They flex side to side while driving also. Some weld-on dual shock hoops would be cool also.
    2. Does in need to be a kit or would you rather have just the Hangers? Both would be nice. Some people have limited fab skills/equipment and have different plans for their truck.
    Angle they built in. The ORU angle does suck, but I don't know a measurement to correct it. Having shackles a little longer than the ORU shackles would be nice. DO NOT MAKE THE SHACKLES WITH A 9/16" HOLE FOR THE SPRINGS! The ORU shackles have a 9/16" hole, when the springs have a 7/16" bolt. I think the hole should be 7/16" so it can be drilled out to whatever size is needed.
    4. Bolt on or Wled on? Or a kit for each? My friends bolted there's on, and then partially welded the brackets to keep them from squeaking or moving.
  3. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    i might just be asking to much hear but a 2x4 set also. as lots of us have 2x4 trucks and thay are much cheeper and more of them avalible. my 1ton crew cab would look great up high with 4x4. and i have the divorced case and gm axle ready to swap in.
    plus it would be great if we could figure out a longer spring like thay did for better ride. but i think thers is custom made.
    100% for sure keep up the idea as i would buy a kit for my truck cause the 73-87 stuff is getting hard to find up hear in the rust belt.
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    all of the places making 4x4 conversions are now manning up and saying they will work on 2x4s. Which I think has always been the case. The bigg issue with 2x4 is the need for the frame modification if you are going to sit low. To many thats a big issue they don't want to take on.
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    the crossmember would have to be a cutom deal unless someone came up with a simple way to cut out the old one and bolt a new one up but i doubght that could happen...
  6. Eastcoast 4WD
    Jan 6, 2006
    45
    Northeast PA
    Hey lets get one thing straight here... a 2x4 is a piece of wood... we aren't making anything out of wood for our trucks, if you are then get out of my thread... just kidding I would certainly entertain the idea of making a bracket that fits a 2wd chassis. If it created a substantial front crossmember then it would be perfectly acceptable to cut out the interfereing crossmember.
  7. Cajun4x4
    Cajun4x4 1/2 ton status
    Oct 17, 2005
    889
    Lafayette, LA
    options would be nice... like have just the brackets available or have a full kit with shock mounts etc. i know i would just want brackets (doing ford towers)
    well first of all i would realy like to see a kit made to accept 52s. i know thats what im using. so far from what ive figured out on my hanger design is to move the front spring hole forward 3" from the ORU location(would theoreticaly move the axle centerline .5" more forward than ORU). then the top rear shackle mount would remain in the same location as the ORU hanger but possibly moved forward 1" using about a 5" shackle... havent realy finalized it all yet, just throwing some things around
    im also looking at making mine to utilize flat bar style shackles. unlike the ORUs(which use those offset shackles) which would require the inboarding of the exact "bushing" placement about .5" or so per side (i hope that makes sense). but keep it in the same vertical location (top shackle hole 4" from the bottom of the frame)
    also a new integrated xmember is a great idea
    bolt on... you can always weld it up later
    5. Price? What would be a reasonable price so that most of you guys would say "It's not worth my time trying to make them my self"
    $300-400ish?
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    ok, you just lost my business. there's no way i want anyone with a sense of humor building parts for my truck. :haha:
    too bad i just ordered the Off Road Direct kit a couple days ago. ah well, this is still in the planning stage, ma ybe i'll get my brackets in time for some educated input on this subject to help make yours that much better.
  9. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,603
    556
    Wasilla AK,
    I'd like to see a kit that uses 56" springs or even 57' ford springs priced below $500. And off the conversion kits and home built jobs I'd like to something stouter for the shackle hangers. the bolt on Idea is cool that way you could weld it up solid and know it was in correct alingment. maybe a 2" receiver in front hanger crossmember
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I agree on the shackle hangers thing. I've not found any of the ones produced very beefy. If it means a few extra dollars for a better product(I'm not saying more than ORU, haha).
  11. 1967k10
    1967k10 1/2 ton status
    Nov 21, 2005
    1,728
    Nebraska looking for D60's
    Options are nice. 52"s would be great on the front. One thing that bothers me with ORU other than the rediculous price is they seem to think you have to use at least 3.5" springs. I'd like my truck to sit 4"-6" above stock,no more. I pull a gooseneck trailer a lot but want a Solid Axle. Would need to be avaliable for 01'+ HD's so I can do my
    D-Max :D . Hopefully you'll have one ready by the time I find a cheap 79' D60.
  12. GRAYTEXK5
    GRAYTEXK5 1/2 ton status
    Jul 23, 2002
    281
    Ft. Worth, TX
    hell, I'd just like to see SOMETHING for the '99 and up body style 1500's. for some reason, none of the other companies seem to care about them. plenty of kits out there for 88-98 body style, and '01 and up HDs...but very little for new body style half tons. so, yeah...that's what I'd be interested in.
  13. 1967k10
    Nov 21, 2005
    1,728
    Any updates. I'm seriously thinking of doing my D-Max this fall.
  14. Eastcoast 4WD
    Jan 6, 2006
    45
    Northeast PA
    One of my subs- just got an '06 duramax and we are woirking out the details on his sas right now.
  15. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
  16. 1967k10
    Nov 21, 2005
    1,728
    Eastcoast 4WD: What's up with that deal? You a one man shop that's overly busy? I hope that's the case. Anyway,what are you thinking cost wise on these? I'd really like to do my D-Max.
  17. yellowK20
    Dec 26, 2002
    7,603
    556
    Wasilla AK,
    make this deal right with the other member hate to see you get a bad reputation unless it's deserved . be careful the "wolves" are circling
  18. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    what ever happened with this?
  19. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    hasnt been here in almost 2 months...
  20. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    Edit: That was in poor taste and I apologize.
