new seal, now back window won't close?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Mar 3, 2002.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    new seal, now back window won\'t close?
    I just replaced all the seals o nmy top...except for the ones on the window, which I think leak...but anyway, the back window seal is pretty good, but the window doesn't want to go up all the way. Its like the seal is too think, and its getting stuck. I have a feeling this is pretty common, but what will cure it? Heat? The other new seals were a really tight fit too. Couldn't get the top completely on till it was bolted down. Have no worries about it leaking there now...
  2. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    Re: new seal, now back window won\'t close?
    I have a similar problem, except mine is real tight (tight enough that the crank exploded the other day while rolling it up) it still goes up and down though. but any way to the top for some more replys /forums/images/icons/smile.gif
  3. johnnyK5
    johnnyK5 Registered Member
    Oct 5, 2001
    95
    Washington, PA
    I have to walk mine up the last inch or so with my hand. I still have the factory seals. My crank is grenaded too, it only grabs 1/4 cog at a time.
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    It the window is lining up correctly in the seal, then chances are that you need more power or some lubricating inside the tailgate. For more power, you will have to check/clean the safety switches and wiring, and/or replace the motor unit.
    I have this dream of running 10 gauge wire all the way from the battery to the tailgate and having a DC-DC converter and control unit inside the tailgate. Then whenever you hit the dash or key switch, that unit would pump out a regulated 18V to the window motor, whether the engine was running or not. But it would take too long for me to build and when everything is right, the factory setup works pretty decent.
  5. dyeager535
    26,980
    Where'd the replacement seals come from?
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    got the seals at LMC. window was a lot slower the first time I rolled it up with the new ones...actually the only time...kina figured I needed to lube it up...whatshould I lube?
