New sending unit now can't pump gas
Discussion in 'The Garage' started by akbound, Jan 9, 2005.
  1. akbound
    akbound 1/2 ton status
    Apr 20, 2004
    San Antonio
    Help!! I wrassled with the gas tank and installed a new sending unit and new hoses at the tank on my '76 Blazer and now it won't take gas at more than a trickle. :confused:
    I hooked up everything like it was before. Is it possible that LMC had some kind of plug on the underside of the vent line? I honestly didn't even look.
    Any ideas?
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    delete
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i'm pretty sure he's talking about filling the tank, not emptying it. check your filler hose/tube for kinks. i'd almost bet that is where you'll find your problem.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    oh, ok, my bad, im pretty tore p right now, i should go to yahoo ro somewhere
    well thats a vent problem yeah check vent hose at top of tank by filler, some of these trucks have this problem from factory, hard to fill, takes forever
    good luck
  5. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    But what if it's not a vent problem? If I completely, completely fill the tank gas does come back up through the vent tube.
    Oh yeah takes me a good ten minutes to put right at three gallons in. Bugs the crap outta me.
    :mad:
  6. akbound
    Apr 20, 2004
    San Antonio
    It must be a problem with the vent. I guess I will take the hose off the vent and put on a longer one and see if I can blow through it. :confused:
    I really don't want to drop the tank again.
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    is a pretty common problem on these vehicles, do some inspecting of the 3/4" or so vent hose and tube at the filler neck down there, has to be problem with it, thats how fill venting takes place and it has to, air has to get out of tank when gas goes in, science of volume displacement
    is plugged, kinked, collapsed, something, there is a cause/reason, has to be at the filler setup there, get flashlight out, poke around, check hose closely, make filler opening bigger, maybe its a bad filler(metal part that you put nozzle into in the bed side, the metal spring loaded flap door in there)
    look in it and around it, flashlight,
    good luck
  8. akbound
    Apr 20, 2004
    San Antonio
    Pumpin!
    The vent hose was kinked above the tank. Luckily I lubed the hoses when I put them on so I was able to wiggle the outboard one far enough to take the kink out. Thanks! :)
