new shackle bushings
Discussion in 'OffRoad Design' started by bp71k5, May 26, 2006.
  1. bp71k5
    bp71k5 3/4 ton status Premium Member
    Mar 31, 2006
    6,239
    284
    San Jose, California
    Hi,
    I'm kinda new at this stuff, but after doing my shakle flip, the bushings on my old shakles are pretty bad (35 year old rubber) Is there a replacement kit that's non-greasable? My axle isn't quite centered on the truck (3/4" closer to the passenger side) anymore. The shakles don't look totalyl vertical so I figure I should replace the bushings while I'm there.
    What do greasable bushings do that non-greased ones don't? This is mostly a weekend driver with trips up to the show in the winter.
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    The greaseable bushings keep everything lubricated and wroking properly. The grease also helps to keep things from rusting ,it also can help with flex.
  3. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,069
    199
    Colorado
    Just to add
    Aftermarket bushings are usually polyurathane. This is a better material for a bushing but the draw back is that can squeek as the suspension moves. The grease helps to keep all of this lubricated and moving freely.
    Just give ORD a call and they can help you out.
