New shocks, for burb. Which ones?
Discussion in 'The Garage' started by rjfguitar, Jan 10, 2005.
  1. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    My dad has a 1998 Suburban 1/2 with 130K and original shocks. While towing the 27' snowmobile trailer the rear wants to bob up and down a little on bad, bumpy roads.
    What shock is basically the best out there? A shock that will help combat the up and down bobbing while towing but also not stiffen up the suspension too much when not in tow is desired. We were looking at the RS5000 Rancho and Pro Comp ES3000's, are the adjustable shocks really worth it? Thanks guys! :)
  2. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Anyone?
  3. dremu
    Feb 27, 2000
    15,952
    444
    East of San Francisco
    Everybody tells me that the Bilsteins are the shiznit ... I donno, as I'm too cheap to have any :D
    -- A
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I just got some $15 from the scratch and dent from Superlift on eBay. They work great.
  5. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    bilsteins! I had them on my 97 stock and then got cheap and went with superlifts at 110k and I think the old bilsteins rode better than the new superlifts.
  6. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    everyone says the adjustable ones are junk, but i sure like my rancho 9000s. i always turn them up w/ heavy loads and it makes a huge difference. i bought mine just causs they were having a buy 3 get one free deal. if i was to buy them again, i'd get the adjustable pro comps, since they are mono tube design.
  7. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    So Chevy used Bilsteins stock? I crawled under the burb and found Biltsteins but figured the previuos owner put them on.
    Jonny-K5, thanks for your thoughts on the adjustable shocks. Anyone else running the adjustable shocks?
  8. tweaker
    tweaker 1/2 ton status
    Mar 21, 2004
    263
    Modesto, CA USof Freakin A
    i'd go with the rancho 5000's. they absorb shock in both upward and downward compressions. heck you can even run them upside down with out any troubles. shouldn't try it with procomps or superlifts. they tend to go out really quick upside down. RANCHO is the way to go.
  9. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    i thought all rancho shocks are triple tube, and all triple tube shocks cant run upside down. procomp ajustables are the only ones i know that are adjustable and mono tube.
    i used to have 5000's on my truck. i thought they were a little stiff. besides, most shocks absorb up and down dont they?
  10. chevydan3
    chevydan3 1/2 ton status
    Nov 27, 2004
    409
    Reno, Nevada
    i hear that rs5000's and es3000's are built by the same company. I run the es3000's just because I like the pro-comp name/quality. good shocks.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Pro comps are just the only inexpensive, adjustable monotubes.
  12. alf4444
    Nov 1, 2002
    2,051
    T-ville, ut.
    not all chevys just the Z71's
  13. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    So a '98 4wd burb would not have bilsteins stock then? The burb doesn't have the Z71 package right? I guess the previous owner put them on then :confused: . My dad ordered the Roadmaster Susupension System out of summit. It is a little coil spring that sits horizontally on top of the leaf pack and is connected to the back of the spring and the u-bolts. It looks like the Rancho Kicker shocks. It is supposed to control axle wrap, bring up the spring rate for less sagging, and help control swaying. We will find out today.
  14. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    No, some burbs came with them.. Dunno what option package was needed to get it though.
    I would go with Bilstein, in fact, thats what I use on several of my rigs.
    My .02,
    John
  15. alf4444
    Nov 1, 2002
    2,051
    T-ville, ut.
    bilsteins are part of the z71 package. The only diff between z71 and others is bilstein shocks decals and skid plates
  16. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Ok, but according to 83ZZ502 some burbs did get Biltseins and I have never seen a burb with the Z71 package.
    Anyway, I guess shocks are now out of the question, the burb has Bilsteins and I removed one and the cylinder is still in good shape. Tommorrow morning we will be installing the Roadmaster suspension system. Hopefully it helps pulling the snowmobile trailer because thats about all there is left that can, besides air bags.
