new spring hangers and poser pics :)
Discussion in 'The Garage' started by k5-newbie, Aug 14, 2005.
  1. k5-newbie
    k5-newbie 1/2 ton status
    Jun 19, 2004
    399
    Huntsville, Texas
    Well, finally finished my front spring hangers today...be easy on my welds i am a welding newbie. Also posted some poser pics to show off the flex :D
  2. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    FYI: always weld along your material (like the frame) never across. Creates a fracture point. Unless it's already cracked, then you kinda have to :D
    Got any more pix? Couldn't really make it all out.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I've heard this before but also seen it done many times with no issue, so is this just something people say or what? I did it on my S10 frame and thoughta bout the fact that maybe I shouldn't have afterwards. I have to do it more when I attach the new crossmember. I mean, its done from the factory , why is doing it when strengthening a frame so bad?
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    sweet truck k5-newbie. with ur zero-rates, did u move the axle forward any or just for extra lift? if you moved it forward, can u take a pic of it just sitting normal? id apprciate it. i want to see how the 1" forward looks in the fenderwells. i see u trimmed the rear part, but did u trim the front?
    looks good!
    thanks
  5. k5-newbie
    Jun 19, 2004
    399
    Huntsville, Texas
    yes, i moved the front forward...will take a pic tomorrow and post it for you, thanks for the compliments.
  6. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    thanks dude. i really like the paint job too.
  7. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Thats not paint, thats bedliner
  8. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    Well I know that when welding on (semi) truck frames, backhoes, land scrapers, etc all the different stuff we repair at the shop, whenever we weld on reinforcements (fish plates), we never weld across the ends, unless we taper the ends of the plate. On a semi truck, you're a lot closer to the breaking point than on a light truck. They get a lot more miles and harder beatings. Also, it's more important on a C channel frame than a boxed frame. When a semi frame cracks, we take all the suspension, etc off, reweld the crack, put 4' long C channel reinforcements inside the frame, and bolt them in with the existing bolts for the suspension, etc. There's almost aways a sticker on the frames that says NOT to drill or weld on the flanges. I don't know anything about your S-10, like tire, engine size or driving style, but if you're mostly stock doing mostly stock stuff, it could be ok. Also depends on what part of the frame, lots of factors, really. Most frames are made to flex...when you weld on something, you create a spot that doesn't want to flex, so it may break. On that big chevy, I wouldn't weld acros the frame right at the spring hanger, which is a stress point. A lot of times, something comes in that's been weded before. You can see where it was cracked, welded, cracked, again, welded, etc. Then you gotta arc-air it all out, weld it up, grind it smooth, and carefully reinforce it to distribute the stress load. Whew! make more sense now? :D
  9. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Semi truck frames are heat treated, but I've read that pick-up truck frames are not, would this make any difference?
  10. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    That tickles a memory in my brain...i think truck frames are...but i can't remember about pickups....sorry! But it would make a difference, for sure.
  11. BL1TZKRIEG
    BL1TZKRIEG 1/2 ton status
    Jan 4, 2005
    196
    OREGON
  12. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    welding - fracture points
    Here's a job I'm working on at work...jackhammer off a backhoe. Notice how the plate broke right at the weld across it. Part of the inside of the crack is actually old and dirty...it was cracked there for awhile before it finally fell off.
  13. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    so what you're saying is it should not have been welded right above where it cracked, where circled in red, right?
  14. Kiwi John
    Kiwi John 1/2 ton status
    Jun 24, 2005
    249
    West Sussex, England, U.K.
    Asuming it was designed by a proper engineer?
    Jackhammers take a lot of vibration - arch enemy of steel fabrication.
    Compared to the weld around the pin-eye hole that broken weld doesn't look to have any penetration along the upper boundary with the main frame. see a dark line there instead of nice grey melt line.
    My welding teacher told me that the area immediatly adjacent to the weld (called the HAZ - Heat Affected Zone) is the weakest. Thats why you have to get your amps etc right, and proper penetration of your weld, and after cooling etc. The Qualified welders on thes forum will be able to expand on this I'm sure.
    Semi frames are heat treated after all the holes are punched, rather than drilled, to help them spring back after twisting I believe.
    Anyway, Nice truck k5newbie. :D :waytogo:
  15. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Its true.
    I'm setting up some homemade Shackle flips in the rear now and the main part was used from a Semi Frame. I can drill holes right through the Blazer frame but this **** is tough. It dulled out my bits real fast.
  16. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    Haha no kidding! We have a big drill with an electromagnetic base that hangs from the crane to drill holes in 'em.
  17. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    Not necessarily. Another part of the problem was that where the bushing was welded in was right at the same point, and the bushing weld did not penetrare the plate at that point. If it wasn't welded there, the plate probably would peel off. Kind of a catch 22. I think it actually broke beacuase someone messed up while hooking up to it with the 'hoe. I just posted it to show that if something is going to break, it's ognna break at the weld.
  18. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Normal pickup frames shouldn't be heat treated. Never seen the "DO NOT WELD FRAME" stickers on light trucks :D
    You see people welding to this stuff all the time, I mean, what does Peterson's do every time thay make a suspension?
    I wouldn't be worried as long as you follow the guidelines : No welding or drilling on flanges
  19. SUPER'BURB
    SUPER'BURB 1/2 ton status
    Jan 9, 2005
    929
    Mountain House, Ca.
    K5-newbie
    Your rig is PIMP!!!!!!! :pimp: :bow:
    The liner paint job rocks and I love your bumpers!! :bow: :waytogo: :saweet:
