New springs..can't get sway bar......(update) thanks for the help..
Discussion in 'The Garage' started by jakeslim, Apr 20, 2003.
  1. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    New springs..can\'t get sway bar......(update) thanks for the help..
    I installed front springs this weekend, everything is done and looks great but I can't get the front sway bar to lineup with the spring plates. Please see pics and questions below.
    Does not line up(above)
    other side.
    Does the bar adjust from here?
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Re: New springs..can\'t get sway bar to line up on spring plates. Please help
    depending on how much lift those are, you need to get a little spacer that goes between the top of the swaybar, and the crossmember
    or you could just do away with the sway bar, Alot of people do this, and i dont think anyone has died yet so it should be ok ;P
  3. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I think it dont fit very well with that much arch. I used the ORD sway bar disconnect kit. Worked for me. Otherwise, mine would of also not fit.
  4. SCOTTS_4X
    SCOTTS_4X 1/2 ton status
    Mar 22, 2002
    129
    Modesto CA
    yes those holes are slotted so you can adjust out the unevenness but the bar will still be too short. you will either need to use the spacers or the ord disconnect kit. all I did was take the damn thing off and forget about it.
    -Scott
  5. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    Thanks for the help. I ordered the ORD disconnect. 3 day express of course!
  6. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    No problemo. Let me know when your truck is done, Im tired of wheeling with the Heeps! /forums/images/graemlins/rotfl.gif
