new starter grinds up flywheel
Discussion in 'The Garage' started by the excuse, Aug 4, 2004.
  1. the excuse
    the excuse 1/2 ton status
    Dec 9, 2003
    209
    san diego
    i just put a new starter in my blazer because the last one was making a weird noise when it started. the new one also makes this noise. somehow its now hitting the flywheel properly and little bits of flywheel grindings are coming out. it aslo sounds horrible.
  2. great scott
    great scott 1/2 ton status
    Dec 31, 2002
    333
    Utah
    My first gues is you need more shims between the block and starter. You can buy a shim kit from your local parts store that should have the shims and a gauge(small rod) to fit the correct amount of shims.
  3. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    yup shim is the word, kit will tell you how to gauge it and have the shims /forums/images/graemlins/woot.gif
  4. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    Can you say "Ring-gear" /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
    Chances are the ring-gear on the flywheel is toast,,,
    you could put 100 starters on it and it will do the same.
    It MAY need shims but I would inspect the ring gear closely 360 degrees and make sure all the teeth are in good shape.
    You can also disconnect the battery lead at the starter and engage the bendix,,, this will throw the starter gear into the flywheel with out turning over the engine. You should be able to stick a straightened out paper clip between the gears,,, if not you may need to shim.
    Better yet if it is the "OLD SCHOOL" type starter,
    pitch it and buy a gear reduction type,,you will thank me later!!!
  5. the excuse
    Dec 9, 2003
    209
    san diego
    flywheel s not missing teeth. i will try disconecting the motor and leaving the solenoid to test the mesh.
  6. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I have been there and done that. tried EVERYTHING. have you ever noticed a stud comming out of the back of the starter that you never use. if you look about the same position on the engine block there are 2 holes. there is actually a bracket that connects the startere to the block.
    if your starter is moving (you will need a friend or remote strarter to do this) when you start it you will need this bracket or make one. if it is not moving try the shims.
    not many people know about this bracket, heck i would still be fighting with it if it were not for my know it all (and he really does know it all) friend thad had one stashed in a bucket in the back of his shop. if you want i can take a pic but wont be back online till tomarrow.
  7. the excuse
    Dec 9, 2003
    209
    san diego
    ok got shims put one in and it was much worse. investigated the mesh more and found that without any shims the tops of the starter teeth are hitting the tops of the flywheel teeth. they arent even meshing together! could i have the wrong starter? i asked for the starter for an 83 blazer with a 350 mine has a carbed 350 in it. what is going on here. please help before my flywheel is shredded to pieces.
  8. csnutrition
    csnutrition Registered Member
    Jan 8, 2003
    16
    North Alabama
    Where did you purchase your starter. I've never had a problem with a brand new Delco starter. However, when I used other brand (i.e. Autozone or other less expensive starters) I had flywheel problems. I was told it had to do with starter bracket.
  9. the excuse
    Dec 9, 2003
    209
    san diego
    this is a $50 pep boys starter.
  10. wasted wages
    Dec 3, 2003
    9,194
    Dallas Texas
    I'm tellin' ya dude,,,,
  11. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    You need to cut the shims in half and reinstall them on one side. That will change the pitch and move the teeth in. It should say in the directions that come with most starters. THat is what I had to do.
  12. the excuse
    Dec 9, 2003
    209
    san diego
    oh ok that makes sense. im poor and cant afford a gear reduction starter. it works now thanks guys.
