New starter replacement
Discussion in 'The Garage' started by SlicksInRain, Feb 11, 2007.
  1. SlicksInRain
    SlicksInRain 1/2 ton status
    Jan 7, 2007
    238
    Chicago, IL
    I think I have to replace my starter because I had to wack it while someone turned my key to get my truck to fire up today. How easy is the starter to change? Is is the simple bolt off and removal of wires or is there timing involved? Also how much do you think this will cost me in parts? Fuel Injected if that means anything.
  2. dyeager535
    26,978
    Pretty simple to remove/install. Hardest part is disconnecting the battery cable, positive leads to the fuse panel, and the start wire from the back of the solenoid before dropping it down. Install is reverse, no it doesn't affect timing or anything. Good idea to disconnect battery cable from battery first though.
    I just had replaced mine under warranty, but I doubt a standard chev starter will run more than $40.
    Edit: doesn't hurt to make sure all your connectors down there are nice and clean, and a bit of connection protecting grease won't hurt either.
  3. 4by4bygod
    4by4bygod 1/2 ton status
    Nov 13, 2003
    3,859
    With My Tinfoil Hat
    Simple bolt on / off.. what I do is take a milk crate under there with me..unbolt the starter, rest it on the crate, then undo the wires.. it's easier than trying to get to the wires with the starter still on there..
    when you put it back together, just reverse your steps...BE CAREFUL when tightening the big nut that holds the power wire on there.. use two wrenches, one to hold the stud in place.. it's easy to snap that stud right off there, especially on these offshore - made pieces..
    beyond that, there's no timing involved or anything.. while you are down there, be sure to grease everything up if you haven't done it for awhile.
    Tom
  4. 4by4bygod
    Nov 13, 2003
    3,859
    With My Tinfoil Hat
    Amen to that.. I forgot to mention that part..
  5. SlicksInRain
    Jan 7, 2007
    238
    Chicago, IL
    I have never done this. I was told it was a cylonoid (sorry if I spelled it wrong) but others say it's the starter because thats what I had to wack. Any thoughts?
  6. dyeager535
    26,978
    Replace them both. You are there, they take as much time to take one out as the other, and they are both old.
    Cheaper to buy both pieces together (starter/solenoid) than it is to buy them separate.
  7. SlicksInRain
    Jan 7, 2007
    238
    Chicago, IL
    My engine is only a year and a half old, but I have a feeling that they used my factory starter thats 17 years old.
  8. lochenjons
    lochenjons 1/2 ton status
    Sep 13, 2006
    682
    Santa Cruz, CA
    If it started when you hit it, it is the cylenoid. Just replace the starter, its easy
