new steering arm mandatory for 4" lift?
Discussion in 'The Garage' started by Lotsa_Faith, Jan 8, 2003.
  1. Lotsa_Faith
    Lotsa_Faith 1/2 ton status
    Jul 10, 2001
    474
    Mckinney, Texas
    new steering arm mandatory for 4\" lift?
    next weekend is going to be my only time to install my lift, then baseball starts up. could I limp it home 12 miles away with the stock arm on? i could leave it sitting until I got the new arm, I just need to get it home. also, let me know if you have an old steering arm. /forums/images/graemlins/k5.gif
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Re: new steering arm mandatory for 4\" lift?
    Yes, you can drive it with a 4" lift and no steering correction.
    -- Mike
  3. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    i wouldnt, the angle of the draglink is to great. It will steer farther one way than the other and may not do what you expect of it in an emergency situation.
  4. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Some people lift 4" and drive it around for years. I wouldn't, but some people do.
    You can certainly drive it 12 miles.
    -- Mike
  5. 87project
    87project Registered Member
    Jul 9, 2002
    98
    Alabama
    got a 4 inch on mine without a drop pitman arm,It still turns good right,left turns like an 18 wheeler
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    [/ QUOTE ] Sounds like your drag link is not adjusted properly. Try turning the key on just far enough to unlock the steering column, then adjust your drag link longer (without moving the angle of the tires) until the steering wheel has made one complete revolution. You should find that the steering is more even from side to side afterwards. /forums/images/graemlins/thumb.gif
    I drove my '77 K5 for years with a 4 inch lift and the stock steering arm. But it did drive better once I ponied up the cash for the correct one. /forums/images/graemlins/shocked.gif
  7. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    You should be fine. You just wont have your full steering radius. I know lots of people that have done this.
