new stuff!!!
Discussion in 'OffRoad Design' started by CCRider, Oct 22, 2001.
  1. CCRider
    CCRider 1/2 ton status
    Jul 8, 2001
    314
    Charlotte North Carolina
    Hey Stephen what can I put behind a 4L80E for a transfer case with a right side front output!! Do you or anyone else make an adapter to join this trans with a 241c??? Let me know , It's for a late model tahoe straight axle conversion! Any Ideas for steering on such a swap?D60/14FF axles thanx CC
    1991 Fullsize 5 1/2"lift, 37"ssr's,10Bolt8 lug , 14Bolt ff, 4:56 Detroit rear, 12"fr. 14"r Bilstein remote res.350 P.F.I , 700r4 , 241c W/ sye
  2. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Sorry to butt in, but take a look at Advance Adaptors website. I believe (if memory serves me), they can adapt a 241 or 400 version of the 205 to the 4L80. It's worth a look.
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot>http://coloradok5.com/gallery/Leadfoot</a>
  3. Stephen
    Sep 15, 2000
    4,228
    144
    Carbondale Colorado
    A right hand 241 from a TH400 should be direct bolt on. The round pattern (rare) 205 would also be a bolt on, possibly with an input gear swap. To use a fig8 205, you'll need an adapter of some sort, I don't know if Advance has exactly the right kit or not, but they have a lot of misc. parts that are good for more than they advertise them for.
    You could also go to a 208 from a TH400 application. They're not the beefiest thing in the world, but they do transfer torque and don't spontaneously explode when you hit dirt.
    You need a factory 4wd output housing on the 4L80 and the 4wd 32 spline output shaft to work with any of this.
    Hope this helps
    oh yeah, putting a 203 behind it for a Doubler would be pretty easy also.......
    Steering: standard crossover stuff. Different dimensions than a straight axle, but that's about it. You could use our pitman and steering arm, then measure for the draglink and be done.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
