New TCI deep pan
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ftn96, Mar 20, 2001.
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    MAN, I got my new TCI Deep aluminum pan for my 700R4 adn the damn thing looks killer and all but the SOB came with metric Allen head bolts to install it. Im a little dis-appointed here. I was ready to install tonight. But Im going to get some 8 point headed grade 3 bolts instead. Just thought I'd share that with you guys. Im venting.
    Will work for beer, parts and tools.
    90 Jimmy 350TBI-700R4-241-33" BFGs-10 bolts w/4.10's
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  2. bigerik
    bigerik 1/2 ton status
    Feb 24, 2001
    184
    Sonoma County, CA
    That sounds great--I want one! But grade 3? Why not grade 5 or 8?
  3. LittleJimmy
    LittleJimmy 1/2 ton status
    Feb 16, 2001
    220
    Channahon IL
    Yeah i got the same pan on mine. I love the fact that it has a drain plug. And i used the allen screws. They are 6m. But if you get different screws make sure you get ones that are the same length as the allen screws. Our new pans are thicker, the old ones from the original pan will not work. Too short. And you will also have to drop the dust cover or the pan will not sit right. If you don't you will see what i mean. anyway just thought i would let you know. Later LittleJimmy.
  4. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    The threads are metric too.
  5. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    How much did the pan run you? Where did you get it?
  6. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    109 bones from Jeg's.
    And what dust cover?
  7. i_4x4
    i_4x4 1/2 ton status
    Feb 20, 2000
    359
    Brighton, Colorado. USA
    The 1 for the torque converter.
    LET'S ROCK
    Don't follow me you will get STUCK!!
  8. Peeetah
    Peeetah Registered Member
    Jul 3, 2000
    97
    Mt. View, CA
    Check this Out!!!
    http://www.expressautocare.com/
    These guys appear to be a fabrication shop in Neveda. They sell aluminum pans for everything and polished alum at that . their price beat the tar out of B&M and TCI! They sell lots of other cool alum stuff!
  9. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Re: Check this Out!!!
    Im still at a loss here. I'm thinking that the only dust cover for the torque converter that I can think of would be on a manual tranny. And mine is the 700. So the torque converter is up inside the bellhousing and the is nowhere close to the pan.
  10. Wheels
    Aug 18, 2000
    638
    The dust shield bolts onto the front of the transmission and covers the bottom side of the torque convertor area. Have to remove it when you pull the tranny to take off the TC bolts. Should be six bolts (3 on each side) and two struts that go from it to the motor mounts. Dont need to really take it off, just loosen the six bolts to make sure the pan sits flush with the case.
  11. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Yep, I figured that one out. I went ahead and took it off to trim the edges to fit with hte new pan. Also had to take the front drive shaft out and had to remove my t-case spacers and jack the damn tranny up as far as it would go and even then the damn pan had to be forced between the hard line that runs under the valve body and the muffler. I now have the pan in, and wiating till tomorrow to finish up.
