New tires from interco
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by white_knight, Oct 15, 2001.
  1. white_knight
    white_knight 1/2 ton status
    Feb 23, 2001
    1,171
    Calgary, Alberta,Canada
    Not sure if this has been posted ....
    but have you guys seen the new tires from interco
    <a target="_blank" href=http://www.intercotire.com/assets/images/truxus_sts_all_terrain-200.jpg>http://www.intercotire.com/assets/images/truxus_sts_all_terrain-200.jpg</a>
    TrXus STS All terrain's
    <a target="_blank" href=http://www.whiteknight.scriptmania.com/>http://www.whiteknight.scriptma
    nia.com
    </a>
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I think I saw those on tyres1.com
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
  3. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    Yeah I saw them at the Anderson 4x4 Nationals this weekend. They weren't marked as AT or anything so I wondered what class they were being marketed under. I thought they were gonna be a sand tire or something of that sort.
    Joe
    RIT Mini-Baja www.rit.edu/~bajawww
    Team Mudnuts www.mudnuts.org
  4. white_knight
    Feb 23, 2001
    1,171
    Here's a write I saw on a Heep sight
    One opinion on the mud terrain
    Interco, one of the foremost manufacturers of aggressive off-road tires, recently introduced a slightly less aggressive and more street-worthy tire to its lineup. The new TRXUS (pronounced: tracks-us) Radial Mud Terrain has been developed to meet the needs of those of us who tackle the rocks, mud, and sand yet also meet the asphalt on a daily basis.
    Construction : At first glance, the TRXUS MT appears to be a condensed relative of the Super Swamper SSR. According to Interco, although the sidewalls are only 2-ply thick, they are supposedly thicker than the 3-ply common in the BFG MT and other off-road tires. With a tighter tread pattern, multiple siping, radial design, and a softer rubber compound; the TRXUS MT should prove to be an excellent choice for both on and off-road driving. IntercoÕs 31x10.5Ó version of this tire did measure a true 31Ó in height. Mounted on a 15x7Ó wheel, the cross-sectional width of the tires measured to be about 10Ó. On a 15x8Ó wheel, the tires would probably be true to IntercoÕs advertised width. Using a depth gauge, both the deepest and shallowest treads were measured. The deepest section of tread measured 19/32Ó and the shallowest measured 13/32Ó.
    On-Road Performance : As expected, the TRXUS MT provides a considerably smooth and quiet on-road drive. Properly balanced and running 31 pounds of pressure, only a subtle hum can be heard on the asphalt. The deceleration ÒgrowlÓ, common among many other mud-terrains, is much less noticeable with the TRXUS MT. On wet roadways, traction is no worse than what I have experienced with the BFG MT. I have yet to experience any skidding while coming to a stop and have not lost control around any turns. Although I consider myself a conservative driver, the extensive siping and Òon-road designÓ put into this tire should keep even a more aggressive driver safe on the asphalt.
    Mud Traction : A recent trip to Tellico, NC proved to be a rather sloppy adventure. Slick rocks, muddy hills, and fresh mud holes seemed to meet us around every turn. The unique tread pattern held its ground on the slick clay-based mud. Although the tread is considerably tight, the mud did not ÒclogÓ the tires. The gummy mud slung out as soon as I was through and managed to make a mess out of the sides of my Jeep. I am not the type to ÒjumpÓ into a mud hole for fun, but having a tire that can man-handle mud is important no matter what type of driver you are.
    On the Rocks : The considerable softness of this tireÕs carcass and the hefty weight of my XJ prompted me to run fairly high pressure on the trail. At 21 pounds of pressure, I was very pleased with the TRXUSÕs performance on the rocks. Although these tires could have been run at a bit lower pressure (17 to 18 pounds), 21 pounds provided a substantial footprint without the worry of losing a tire on the trail. With a controlled right foot, the TRXUS's allowed me to climb up (pretty much) anything that I could point them at. The tires grabbed the rocks with very little to no slippage the entire trip.
    Conclusion : I am extremely pleased with the performance of these tires so far. I spend the majority of my time on road and often travel long distances between home and school. I do, however, go off-road quite a bit. With at least 2 trips planned per month, a tire with excellent off-road traction is a necessity. Over the next several months I plan to tackle Uwharrie, Tellico, Camp Jeep, and some of my local stomping ground. Check back for a 10,000 mile review later this year!
    nia.com
    </a>
  5. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    some one already posted that i think it might of been "check out these tires" or some thing like that
    high
  6. BIGRIG
    BIGRIG 1/2 ton status
    Feb 29, 2000
    488
    Independence, MO
    that article is for the mud-terrain they also made it does look just like the ssr....the one showing is the new all-terrain.
    MY DRINKING TEAM HAS A FOUR WHEELING PROBLEM![​IMG]
