New to 2nd gen., Lift ?'s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by LucasJ03, Apr 3, 2004.
  1. LucasJ03
    LucasJ03 1/2 ton status
    Sep 18, 2002
    289
    Ft. Fun, Colorado
    New to 2nd gen., Lift ?\'s
    I just bought a stock 90' K5, I want to lift it probably 4" w/35" tires. My question is does a 4" lift elimnate the rear end sag or do I need to get 6" springs in the rear to level it out. Thanks in advance.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Re: New to 2nd gen., Lift ?\'s
    It will if you get new springs. If its sagged now, blocks will let it sag. If its not real bad a shackle flip may level it out. In my case the rear springs were ok and rear now sits up a hair, and trailbox about levels it (heavy with spares). /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
    BTW if its real bad sagging you can do shackle flip and zero rate add a leaf, see ORD
  3. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    You have to realize the rear springs are used and old, so that can be a reason they sag. If you need to level you can get a zero rate.
