New to CK5, RuffStuff Specialties.....
Discussion in 'Vendor Forum' started by Gravel Maker, Mar 7, 2006.
  1. Gravel Maker
    Gravel Maker 1/2 ton status Vendor
    Feb 6, 2006
    2,572
    23
    Sacramento, CA
    Been gettin alot of visits from CK5 members so I decided we had better join so you can see what we have to offer. We make Tabs, Brackets, Reinforcement Items, Shackles, Spring Perches, Hangers, essentially all the things needed to tie it all together. We make everything we sell.
    I confess we do not have many items specifically for any vehicle, we make the things that would go on any vehicle, and we make them to last. All of our items are at least .25" thick and the real workhorse items like Suspension Links are .375" thick. So look to us for bomber stuff! Everything is made in the USA, and it always will be.
    [​IMG][​IMG]
    [​IMG][​IMG]
    Our pricing will suprise you! We also support Clubs of every kind so lets consider CK5 a club to and in our support we give every club member an additional 10% discount (use CK510 code on checkout).And if you are a shop owner call me about Wholesale, we don't play that tier system crap and no minimum order either!:eek1: Small shops are the innovators, why should they be held down.
    We are adding 10 items a week and there are some blank spots on the website but if they are there something is in progress and will be there soon so keep checking back! BTW, our website isn't full of bells and whistles, those just add to cost.
    Dan Fredrickson
    916.600.1945
    www.ruffstuffspecialties.com
    dan@ruffstuffspecialties.com
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Cool!!
    Put your website in your signature ;)
  3. TRAILTOYZ
    TRAILTOYZ 1/2 ton status
    May 21, 2005
    106
    Wasilla, AK
    Well, guess I'll go delete my post now :rolleyes:
  4. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    What post??
    Are you the guy I am talking to about a camera for my RV and K5....? I think I found you on Pirate but good to see you here also :D
  5. Gravel Maker
    Feb 6, 2006
    2,572
    23
    Sacramento, CA
    Got a couple of questions.....
    So here you are:
    Yes we accept PayPal with no surcharge.
    Yes we have disk caliper brackets, we ran a sellout sale last weekend so we could introduce new models, stronger and less expensive, coming this Friday through next Friday.
    Yes, we are making 3 varieties of truss, 1st rear truss this Friday or next Monday.
    Yes, Yes, Yes.
    Thanks for the support, in the next 2.5 months we are rolling out 35 more parts to add to the 90+ we make now.:wink1:
  6. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Oh boy! Another place to spend my money. I love it.
  7. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    how bout more info on the trusses I need one for a 12 bolt!
  8. Gravel Maker
    Feb 6, 2006
    2,572
    23
    Sacramento, CA
    Should be able to Post the Prototype......
    Pic Monday afternoon.....watch for it.
  9. sweetk30
    Nov 1, 2004
    25,539
    539
    horseheads , ny 14845
    sweet. only problem i see is lack of 2.5 wide spring stuff. most of it is 3.0 wide. are gm stuff runs 2.5. keep up the good work.
    and you might want to look in to axle wrap bars or kits of some kind. we like those .
  10. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Are you forgetting about the aftermarket bushings that stick out on the sides of the springs to bring them to 3"?
  11. Gravel Maker
    Feb 6, 2006
    2,572
    23
    Sacramento, CA
    Ok, we are no longer talking about Spring perches.....
    :confused: On the axle end of the anti-wrap / track /traction bar we are set up for an industry standard 2.625 joint, on the other end we would use (generally) with 3" spacing allowing for the bushing . We make brackets only at this point, kits to follow (2-3 weeks).
  12. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    ooooo i could definitely go for a pair of axle wrap bars:D
  13. sweetk30
    Nov 1, 2004
    25,539
    539
    ya your right yunit:doah: but dont forget the spring perches are still 2.5 wide. ;)
  14. Gravel Maker
    Feb 6, 2006
    2,572
    23
    Sacramento, CA
    And thats why we make spring hangers in 3 different widths....
    Including 3.0"......
  15. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    where in sac?
  16. Gravel Maker
    Feb 6, 2006
    2,572
    23
    Sacramento, CA
    We are in Orangevale......
    We are primarily a Wholesale Manufacturer and OEM Manufacturer, we do not have a retail Location. We can arrange to pickup parts so you can save freight though. However we use USPS Flat rate Boxes whenever possible so shipping cost is not really an issue (9.45 anywhere in US for 70 lbs.).
  17. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    just curious, used to live off 5 south and pocket rd.
  18. Gravel Maker
    Feb 6, 2006
    2,572
    23
    Sacramento, CA
    A clarification.....and correction.....
    :mad: I said 3.0" wide for perches, we make 3 widths of Spring perch, 2" for early CJ and MB series, 2.25" for later of the same, and 2.5" wide for GM, Toy and nearly everything else. I think I had 3.0" on my mind because we are adding those to our lineup. We make Ubolt plates to go with them and Cromo Ubolts too. The 2.0" wide perches are cut for the smaller diameter 2.5" axle tubes, the 2.25 are cut for the 2.75 diameter D44 tubes, and the 2.5 are cut 3.1 so they can quickly be sized for 3.0" - 3.25" tubes quickly. More clear I hope.....
