NEW to GMC - Whats all bout this cracked frame problem..lookin at a 74
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by maddog71, Jun 18, 2002.
  1. maddog71
    maddog71 Registered Member
    May 15, 2002
    10
    Hi
    New to this forum. I will be looking at a 74 Jimmy tomorrow. I saw the posts about the cracked frame problem.
    Is that very common when oversized tires are used???
    please let me know of anything else I should look for.
    thanks!
    adam
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Welcome to this site. Yes, cracked frames around the steering box is a common problem with GM frames. In the later years GM even added extra support in that area. It is more of a common problem once the vehicle is lifted and has larger tires installed. www.offroaddesign.com sells the necessary supports to help alleviate this problem.
  3. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Yep it's pretty common at the steering box also look for rust in the rockers and look under the carpet up front where you'd put your feet for rust also chekt to see if the engine and tranny mounts are rotted...All I got right now...
  4. little79k5
    little79k5 1/2 ton status
    Mar 27, 2002
    230
    panama city, fl
    also check out the tailpan area. where the tailgate bolts up for rust. very common. just lift up carpet a little
  5. Headbanger
    Headbanger 1/2 ton status
    Nov 29, 2001
    123
    Moreno Valley, California. U.S.A.
    ORD has a good set of reinforcement plates and a crossmember brace to help with that problem. I have them on my 89 and so far so good!! /forums/images/icons/wink.gif
  6. chevyfumes
    Feb 24, 2000
    38,584
    266
    So it's a day later did you look at the 74 if so what did you find out.....?
