NEW (to me) M1008 want to swap in 4l80e, questions...
Discussion in 'The Garage' started by Slickm1008, Jan 13, 2011.
  1. Slickm1008
    Slickm1008 Registered Member
    Nov 6, 2010
    35
    MI
    :doah:
    so,
    I just bought fourbyken's M1008 and so far so good, except I'm NOT digg'n the 55mph top speed.
    As such i wana do an overdrive mod to the vehicle.
    SO.... what's the BEST way to do this without breaking the bank? I'm lean'n towards a 4l80e cause I like the idea of an automatic in a pick up BUT I see the compushift ECM is $1200 alone THEN i'd need to find a DECENT 4l80e, THEN have it all installed!!!
    so it's look'n like it's a $3k swap by the time yer all said & done???
    I'm NOT going to put a 700r4 in it, NOBODY says it'll hold up, the Gear Vendors seems even WORSE of an idea as it costs like $2500 and ONLY works for ya in 2wd AND always has the torque converter working overtime...
    SO, what's yer best suggestion???
    What am I look'n at to do a NV4500 manual swap? ...bout the same $$ wise as a 4l80e all said & done, or way cheaper??
    :dunno:
    I'm at a bit of a loss... lil help would be a HUGE step down the right path!
    thx guys!!!
    :pimp:
  2. thatK30guy
    Jan 12, 2001
    32,032
    42
    Swap in 4.10 gears.
    Or even 3.73, too.
  3. scottsdale86
    scottsdale86 1/2 ton status
    Oct 19, 2010
    1,124
    San Bernardino ca
    Who says a properly built 700r4 won't hold up? How much HP and Torque are you making?
  4. sixb
    sixb 1/2 ton status
    Feb 11, 2008
    1,141
    West Jordan UT
    I say keep the 4.56s and go to a 35" tire with a built 700r4:D
    Way cheaper than a 4l80e or the nv4500 swaps and a complete bolt in.
  5. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
  6. Stomis
    Stomis Professional Amateur Premium Member
    Nov 20, 2007
    9,864
    106
    Roseland VA/PtPleasant NJ
    Seriously a well built 700 will live no problem behind a 6.2.
    If your still dead set you dont want one then the cheapest 4L80e route is to pull a harness and a trans from a 1993 auto 6.5 turbo truck. Its a needle in a haystack but that year was mechanical pump 6.5T with a 4L80e with a standalone factory harness and computer. And if you do find that needle you might as well grab that 6.5T also...
  7. sweetk30
    Nov 1, 2004
    24,868
    166
    horseheads , ny 14845
  8. Slickm1008
    Nov 6, 2010
    35
    MI
    My plans are to do the 3.73 ratio, it already has 33' tires and am STRONGLY concidering a banks turbo.
    i just can't understand how a 1/2 ton trans (700r4) would hold up well in stock form behind a turbo 6.2, if i end up towing a goose neck or equopment trailor, unless it is a BUILT 700r4... and if you spend to build a built 700 why not get the 4l80e??
    I'm a ford guy so I'm new to the GM side of the fence here, but I just don't wana save $$ on a swap just to have to replace a later cause I went cheaper... or would i really need to build up a 4l80e also?
    just look'n to hear from some of you who have done a swap to an overdrive in yer rig and hear what you would do if you had to do it over etc
    lol in short HELP!
    :bow:
  9. bailey9r
    bailey9r 1/2 ton status
    Feb 6, 2008
    300
    High Springs Fl
    My 6.2 blazer came from the factory with a 700 and it lasted 137000 miles. I had it rebuilt with upgraded parts for 1300.00 (including the new diesel TC) and it is going strong with 32's and 342 gears. Thats about as hard a combo on a tranny as it gets, high gears and my lead foot. :doah:
  10. K5dreamer
    K5dreamer 1/2 ton status
    Mar 14, 2005
    3,086
    Alexandria, Va
    when i was debating going 4l80, i was gonna just put the trans in, with a manual valvebody, and manualy shift it through the gears. no ECU needed. be kind of annoying really, and all said and done, id rather have a five speed if im rowing the gears, as such ive decided to go with an NV4500. although for that 6.2, you could go the cheaper route and get an NV3550, there are several on here running the NV3500, and say its gear spacing is better for the diesel engine. and should be strong enough to run it just fine.
  11. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,761
    60
    Paducah, KY
    If he's planning on using this thing to tow or haul like I just highlighted there then he doesn't want a NV3500. I'd say swap in a NV4500 and keep the 4.56's.
    How much are you planning on hauling/towing? Realize this is a 26-27 year old 1 ton truck with the diesel equivalent of a carbed 350. It's not a Cummins Ram 3500 or a Powerstroke F350.
  12. Slickm1008
    Nov 6, 2010
    35
    MI
    I pull a mid size kubota 4x4 tractor, and misc equip trailers snowmobiles & atv's and I plan to get 1 of those camper/atv trailers... So I'd be use'n ALL of a standard 3/4 ton's abilities in my thinking at-least
    I suppose it's worth mentioning I'm hope'n to achieve 25 mpg for usual drive'n
    ...as it is, it shifts into 3rd gear @ about 28 mph, just WINDS out from there... So much so that it's scream'n go'n a mere 58 mph
    As I say, THANK YOU all for the input!!! I'm hope'n to be happy with the results after the 1st attempt & not have to reREdo everything... & that's where u guys are invaluable!!!
    Thx & keep the good advice coming
  13. Stomis
    Nov 20, 2007
    9,864
    106
    Swap to a stick if your after mileage like that. Honestly a NA 6.2 isnt pulling a gooseneck trailer very well. Especially in anything more than flat ground.
    I'd start looking into 6.5T swaps at the least.
  14. AJMBLAZER
    May 18, 2000
    22,761
    60
    Paducah, KY
    Good luck getting 25mpg. You'd be lucky to touch 20mpg with one at the ideal cruising speed, well geared and setup, with low resistance tires on the freeway. You'd likely see high teens if you added OD and a turbo and drove it nicely.
    Keep in mind the tow rating for these things was only like 8000lbs in 1986.
  15. K5dreamer
    Mar 14, 2005
    3,086
    Alexandria, Va
    WHOOPS missed the 2nd post. my bad. yeah ignore the nv3500.
  16. BoondocK5
    BoondocK5 1 ton status Premium Member Author
    May 13, 2006
    10,000
    17
    Salt Lake City, Utah
    Can you back this statement up with any kind of factual data? Not being a dick, just curious. as I don't want to spend the time and effort to build up a four speed automatic, just to have to change to some other trans because of a strength/durability issue.
    I'll be running a mild built 5.7 TBI engine for now and a 4bt when money and time permit. But, the drive train behind the engine I don't want to change it once it's built. My CC will probably weigh in around 6500-7K lbs when complete.
  17. bailey9r
    Feb 6, 2008
    300
    High Springs Fl
  18. scottsdale86
    Oct 19, 2010
    1,124
    San Bernardino ca
    A 4BT or mild 5.7 chevy are A LOT different then the 6.2 NA diesel he asked about, There are plenty of online resources and shops that will and can build a 700r4 for well over 400 hp and do it on a regular basis.
  19. Kenny78
    Kenny78 1/2 ton status
    Nov 7, 2007
    482
    Around Tulsa, Oklahoma
    An Optshift controller is $590 with controller. It's working great so far. If I have read the compushift forums right then the optishift has less tunability, but for half price it should be expected. Line pressure, all shift points up and down for all speeds, TCC firmness is tunable on laptop and more crude adjustments and also all inputs can be made w/o laptops. You should be able to grab a 4wd 4l80e used with converter for $550 or under.If you grab a pre 96 4wd you might get lucky and have a rear speed sensor reluctor, but I didn't. I got a quote from a trans. shop that was reasonable but I had already invested in my other solution. The diff. mounted reluctor is temporary but will work until I rebuild the trans. You could also just get a electric np241 and accompanying elec. speedo.
    My incompleted thread. http://coloradok5.com/forums/showthread.php?t=278030
    If you are going to an OD trans I would not regear. The OD gear is .7?? and dropped my gas RPM's at 65mph almost 1000 RPM.
