New to the Forum, Lots Of ????????????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by LostChild, Mar 28, 2006.
  1. LostChild
    LostChild Registered Member
    Mar 28, 2006
    60
    PoeDunk Utah
    My first rig was a 86 Samurai, and I just sold it for a 81 blazer that I picked up for 500 bucks, it has a 350 with an edelbrock 600 carb, and the reat is bone stock. I am planning on Installing a tough country 4'' ez ride suspension, with blocks in the rear ( just for right now) Along with ORD Bolt on steering box brace kit, and there swaybar correction/disconnenect kit, 33x12.50 tires on 15'' rims. But I am wanting to know if I install the 4'' lift will I hae to get new drive shafts or can I get drive shaft extensions, I am only going to run this lift for a year or so and then I will up grade to the ORD rear shackle flip and HD shackels with 2'' lifted HD leaf springs, 14 bolt axle in the read and 6'' HD lifted springs in the front with a dana 60 and some other dodads, so what do I need to have parts wise in order to install the 4'' for now. thanks for any help you can offer.:D
  2. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    with only a 4 inch lift there are no necessary mods that i know of...i have the 4 inch lift and we didnt do anything...i think as soon as you go higher than 4 you`ll have to do some mods
    good luck
  3. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Might need longer brake lines
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I went shackle flip from the get go in the rear , and immediately had vibrations . Something to think about when you do get around to the flip .
    I went ahead and had a CV shaft made to the right length for the rear .
    The front shaft , on mine with 4 inch lift , has worked well with no change .
    Do spring for the brake lines , and forget about the extensions in the kit .
  5. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    Might need a rised steering arm or droppd draglink.
  6. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    well those "usually" come with the lift kit
  7. LostChild
    Mar 28, 2006
    60
    PoeDunk Utah
    Thanks for all of the responses and info, What about the 208 transfer case If I can get my hands on a used nP205 or a new one will It swap right in or do I have to get some kind of adapter or new T-case mount.
  8. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    IMHO unless you are having probs with the 208 keep it until you are doing a major drivetrain swap, if that is in fact your plan. just keep it filled up with fluid and it should be fine. I know some guys with 4" lifts and both driveshafts were fine but check to make sure the steering correction comes with the lift kit cause you will need that Good luck with stuff
  9. LostChild
    Mar 28, 2006
    60
    PoeDunk Utah
    I am geting the steer arm with the lift kit and a set of procomp steel braid brake lines will I need to change my gear ratio to run 33's or will it be ok untile I upgrade my axles, t-case and go up to a 6'' lift?
  10. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    stock gears are fine...thats what i`m running
  11. LostChild
    Mar 28, 2006
    60
    PoeDunk Utah
    Right on I will just run my 208 untile change out the transmission and the front and rear axles. I went throgh the vendors forum and found alot of good stuff there, did any one pick up one of the CK5 hitch covers? if so do you have any pics you can post.
