New to the K-5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ryan, Jan 17, 2001.
  1. Ryan
    Ryan Registered Member
    Jan 17, 2001
    27
    Eastern NC
    I have had a 1983 Chevy 2WD truck for many years, however I recently purchased a 1990 K-5. I'm sure the question has been posted before, however, I'm new. The top has never been off. I have taken all the VISIBLE bolts off, with the exception of the four in the rear that are only accessible by removing the rear speaker. How does the top come off? Did GM not want the top to be removed easily? What to do with the seat belt boxes that are bolted to the top! I have managed to get the front to lift about 2 inches. Any help would be appreciated.
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Just take the four in the back off, and it will come off. It may require some force, its probably sealed on there pretty good. Congrats on your purchase.
    90K5
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I've got an 83 and underneath the top at the rear there is 1 more on each side that need to come off also! Last time I took them off I left the two underbolts off. It took a little force but the whole top came off in one swoop. Where do you live you can take the top off in January? Too cold even in Tucson!
    creepin' and crawlin'
    Jim
  4. Eric78K5
    Eric78K5 1/2 ton status
    Feb 18, 2000
    230
    South Carolina
    Welcome to ColoradoK5!! And congrats on the purchase of your Blazer!
    On a more helpful note, I agree with the others, after you get the other bolts out, it will take a good amount of force to get the top off if it hasn't been off before. Make sure you have a buddy handy, that thing is heavy!
    Eric78K5
    K5-Because Size Matters!
  5. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    My 89 has two Tamper Proof Torx bolts near the rear that kep the top from coming off...if you can lift the front 2", the these are probably the bolts that are hindering your progress.....I wouldn't think you'd be able to break the front loose and not the rear....be careful not to damage the gasket and make sure you clean/lube it before you replace it....the most common place for leaks is at the gasket between the cab roof and topper....good luck.....JD
    I'm at 10th and Plum....10 miles from nowhere, and Plum out in the sticks....
  6. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Ryan
    Welcome to ColoradoK5 and congrats on your new K5.
    Jimmyjack
    You know how it is you get a new covertable the first thing you wanna do is take the top off at any cost.
    HEE-HAW .... tops off time to play
    <font color=blue>Professional <font color=red>JEEP EATER</font color=red>, it's a population control thing.</font color=blue>
