new to this style blazer some questions
Discussion in '1992-Present Chevy & GMC models' started by KENNY, May 17, 2003.
  1. KENNY
    KENNY 1/2 ton status
    Dec 7, 2000
    292
    nyc
    hello. just purchased a 92 blazer 1500 with a ton of mileage but running well. some questions since i am not familiar with this body style.any thing in particular i shoul or should have looked for . what size tires can i run stock. can i transfer my msd ignition box/ and where is the computer control on this truck? thanks /forums/images/graemlins/thumb.gif
  2. bigred350
    bigred350 Registered Member
    Jan 29, 2003
    11
    florence AL
    you can run 285/75 on stock wheels. im not sure about the MSD thing.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    behind the glovebox or behind the passenger kicker panel. Not sure which.
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    since when can an IFS truck run 33s stock? 285/75s are 32.8x11.5 approximately. I didn't know an IFS could handle that.
  5. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I had the 285s on my truck before the SAS, and if the upper ball joint wasn't wasted, it wouldn't rub, even with the fender flares on it. I saw a truck awhile ago, 2500 4x4 8 lug, that had 33s on 10" wheels. Didn't look bad, but don't know how bad it rubbed, we were going in a straight line down the road.
  6. Shorts
    Shorts 1/2 ton status
    Oct 16, 2001
    336
    CC & SA, Tx
    IFS can handle that - its only 1.2" taller than a 265. 285s do fit stock chevy 4x4 on stock wheels. if you try running them on aftermarkets, they'll rub.
    IFS can handle up to a 35", but that's all i'd want to put on my truck. yea, it'll "handle" bigger than 35s, but it'd be a street queen to do that.
    btw, since you got a new blazer, pick upa chilton's manual from the store, it'll tell you just about anything you need to know about specs and maintenance on the truck. dig in your glovebox and read the RPO codes in there. search online for "RPO codes" - and you can see what options your truck was built with.
  7. KENNY
    Dec 7, 2000
    292
    nyc
    i have 31's on my 84 that i was thinking of transfering to the newer truck that's why i asked. but i might just stay stock. expect to hear some more from me as i learn more about the new style body
  8. Shorts
    Oct 16, 2001
    336
    CC & SA, Tx
    cool - you got any questions, ask away /forums/images/graemlins/cool.gif
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Before you try to move the tires, read the sidewalls on both trucks. Our '94 Sub came with 16-inch factory wheels. If your new Blazer has 16's, then the 15's from your '84 aren't going to be of much use to you. /forums/images/graemlins/frown.gif
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    you can fit 15" rims off an older k5 on the newer blazer, just takes some caliper grinding.
  11. Shorts
    Oct 16, 2001
    336
    CC & SA, Tx
    actually, if the 15s are 6 lug, they'll fit. and if the tires on those 15s are 31s, they should fit as well. the 31s aren't tall enough to cause any rubbing issues, and i doubt the width would either. what's the type of wheels on the 84? what's the backspacing? that could make a difference.
    the only thing i could that 15s being any trouble would be the edge of the caliper rubbing the inside of the wheel. if that's the case, then the caliper can easily and safely be ground enough to not scrape the wheel anymore. i have 15s on my truck, and had to grind the sharp corner off the caliper.
  12. KENNY
    Dec 7, 2000
    292
    nyc
    think i'm going to stay with the 16's which i believe are the original rims. what would be a good beefy tire for street use.thanks for the response guys
  13. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    just street use? I am going with Goodyear 285/75R16 MT/Rs I believe.
  14. KENNY
    Dec 7, 2000
    292
    nyc
    yeah this one will see no mud just some snow. will get another for that stuff.
  15. 89K1500Chevy
    89K1500Chevy 1/2 ton status
    Nov 9, 2002
    645
    Georgia, Fayetteville
    yeah but then youll be out in the backyard mudding..
    I did on accident the otherday moving some stuff into the basement when it started pouring down rain and now there is 2 really big ruts going down beside my house to the back yard it was crazy tires throwing grass and dirt everywhere the yard was so slick that when i put it in gear in 4 lo to creep outta there it started digging ruts i almost got stuck till i backed up to get a rolling start its a good slope. anyways yeah it was [naughty word] but i made it out of there.... /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif www.zombieoffroading.8m.net how long do the MT/Rs last on the road?
