New towhooks
Discussion in 'The Garage' started by chosen(1), May 25, 2006.
  1. chosen(1)
    chosen(1) 1/2 ton status
    Nov 19, 2002
    206
    Michigan
    When I got my truck it didn't have any towhooks in the front. Like many of us I tried the cheapie auto parts store hooks, and they were fine, but I wanted a set of factory hooks because I've had them in the past, and they seemed to be pretty strong. However I started reading some things here and decided to go with something bigger, with a closed loop. I did some searching on the 'bay and found some f-250/350 factory hooks for around $20, and figured "I'll make 'em work".
    So, what do you think?
    -- Ignore the oil spots, previous truck --
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Looks pretty good.
  3. yoshisv
    yoshisv 1/2 ton status
    Feb 19, 2006
    266
    Hartsville, Tennessee
    I like Them:laugh:
  4. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    yeah, not bad at all. they probably will get less use than the did on the ford. haha. on another note, did you put bedliner on your grille and body? pretty cool, if so. i've only seen a few like that in person.
  5. JNygard
    JNygard Registered Member
    Mar 19, 2003
    45
    Nampa ID
    I like it.
    I have picked up a set of those also and was trying to figure out how I was going to mount them.
    Any problems I need to lookout for when mounting the hooks there?
  6. chosen(1)
    Nov 19, 2002
    206
    Michigan
    The only concern I came up with is that there isn't much frame material in front of the front bolt, but I bolted them through the frame and bumper bracket, so there is plenty of metal there (the bumper bracket). The other two bolts are back far enough not to worry about.
