New tranny, torque converter clutch question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kore0015, Oct 17, 2006.
  1. kore0015
    kore0015 Registered Member
    Mar 1, 2006
    9
    Ft Lewis, WA
    I have an '80 Blazer. I just bought a remanufactured 350 auto transmission. The tranny looked identical to my old one until I got to the electrical connection. Both trannies have a 2 wire oval plug, but in my old one only one wire was used. This new one uses both wires. I figured out that these wires are for the TCC (Torque Converter Clutch). I guess my old one was internally grounding. This new tranny relies on a ground from an external circuit, I guess. Do I just ground the 2nd wire?
    If I don't connect the second wire will my torque converter not lock up? If I hook it to ground will it short the TCC solenoid and lock the thing up constantly? Can I just replace the TCC solenoid with one that grounds inside the tranny?
  2. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    I am thinking yours has a spark retard for emissions ? I don't think it has anthing to do with the TC ? Pull the pan on your old one and look at the valve body . If it has lockup you should see wiring going to the valve ?
  3. kore0015
    Mar 1, 2006
    9
    Ft Lewis, WA
    Looks like this is a nevermind. It was the sales guy at the tranny shop that told me this was a problem. He said there was no external/quick fix. The trannies were radically different. After about the 8th call to the transmission shop, the front desk idiot finally went and talked to one of the rebuilders. They said no big deal. Ignore the second wire. So after 2 days of headaches and hours of reading and researching I learned I was sitting on the right tranny all along. What a moron. Oh well. I guess I'll find out for sure once I get the thing running.
