new trans... got numbers!
Discussion in 'The Garage' started by noJeepshere, Feb 10, 2004.
  1. noJeepshere
    noJeepshere I Drive Trains! Premium Member
    Jan 2, 2003
    8,581
    748
    City of Sand, UT
    my very good freind who so happens to have a garage /forums/images/graemlins/thumb.gif also has a New Process tranny in his garage. itsa 5spd with 25% overdrive. he had it in a school bus for years then he tore it out after it got t-boned and junked. he rebuilt the tranny and has it sittin in his garage. he wants to get rid of it for $400. it will bolt to my engine but i need an adapter for the t-case. does anyone know of a manufacturer that has a part for this? or do i need to fab one up myself? thanks for your input. /forums/images/graemlins/ears.gif
  2. dyeager535
    26,978
    Re: new trans...
    Is it the NV4500, or somethign bigger?
    Advanced Adapters is about the only place I know with a large selection of those kind of parts, although there might be more out there.
  3. noJeepshere
    Jan 2, 2003
    8,581
    748
    City of Sand, UT
    Re: new trans...
    sorry i dont get on the net much, too busy with school work. no, its not a nv4500, its got a funky shifting pattern, from what he says, its like this
    r 3 5
    1 2 4
    not sure, though, gotta put it in to be sure.
    ill get the number on the side of the trans as soon as i get home.
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    Re: new trans...
    that is the normal OD tranny shift pattern in med to heavy applications
    get the data tag info and post it
  5. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Re: new trans...
    r 3 5
    1 2 4
    /forums/images/graemlins/eek.gifThat might take me a little wile to get used to... I think I would grind a few gears /forums/images/graemlins/grin.gif
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    Re: new trans...
    whoops
    that should be
    r 2 5
    1 3 4
    it is the only pattern that makes sense in a purpose built 5 speed case with OD
    the ones with OD hanging out the back of a 4 speed case are the oddballs
  7. noJeepshere
    Jan 2, 2003
    8,581
    748
    City of Sand, UT
    Re: new trans...
    ok, i got the numbers stamped on the side of the tranny.
    first there is a tag that is screwed on that says 10-12-62, im guessing that is the manufacture date. then some numbers that are cast into the block,
    C 91861 AD
  8. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    Re: new trans...
    Could it possibly be a Clark tranny? I've heard that a lot of older industrial trucks and school busses had them.
    Kris
  9. noJeepshere
    Jan 2, 2003
    8,581
    748
    City of Sand, UT
    Re: new trans...
    nope, its a new process tranny. forgot to put that down too. /forums/images/graemlins/whistling.gif its got the NP star symbol on the side
  10. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    Re: new trans...
    could be the NP5600
  11. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Re: new trans...
    No, those are 6 speeds. This is only a 5.
