New transfer case mod possibly?
Discussion in 'The Garage' started by Thumper, Aug 22, 2004.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    I was just out at my buddys place helping him with his CJ-7. He is in the process of swapping in a Vortec V-6 fuellie from an S-10 into his Heep. He has found a SM420 tranny and has it hooked to his D300 T-case. We were talking about crawl ratios etc, and he figures that he is going to be around 96:1 with his setup. We figured mine out to be 53.1:1 with my 465, 205, and 4:10s. He says the Dana300 case is a gear drive case with a 2.62:1 low range. If I swapped one of those behind my 465, it would put me up to 70.3:1. It cost him around $500.00 for the adapter from the GM tranny to the AMC case. I am seriously contemplatin this... is it worth $500.00 for the adapter, and $150.00 for a D300 case to gain nearly 20:1 worth of crawl ratio?
    Has anyone already done this swap?
    Mike
  2. Thumper
    1,582
    Alberta Canada
    No thoughts or opinions?
    Mike
  3. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I'm not sure how strong a Dana 300 is and it seems that the cost is approaching doubler country. I know the Heep guys swear by them.
  4. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    ya for that price, either get a 208 or 241 for a poor man doubler...or get a 203 range box and ORD's doubler kit for some real crawl ratio!! bout 105:1 /forums/images/graemlins/peace.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  5. tRustyK5
    Jul 23, 2000
    36,169
    1,369
    E-town baby!
    Mike
    In a full size truck with a big block and 38's you'd nuke that D300 in no time.
    Rene
  6. Thumper
    1,582
    Alberta Canada
    Are these both not chain drive units? The D300 is a gear drive same as a 205.
    And as far as a doubler... the price is about half one. I can get this setup for around 650.00 CDN, where as ORD doubler is around 1200.00 USD plus finding a range box, and a new 465/ 205 setup with the right spline count since no-one finds it necessary to make a 10 spline kit anymore. So... at 650.00 vs 2000.00 the price doesnt compare. Way less than half. As for strength... they ran these cases behind AMC 360s. The info I have is that they are very strong. Lots of Jeep guys run them behind 360s or 350s with NV4500s. Hmm... worth doing some research tho. I needed some input. /forums/images/graemlins/thumb.gif
    Mike
  7. smprider112
    May 1, 2004
    624
    Beaverton,Oregon
    they are chain...but prolly about as strong as a 300 is...regardless its gear driven, doesnt mean its any where near as strong as a 205...I'd look into a 208 or 241 still /forums/images/graemlins/thumb.gif
  8. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I'm pretty sure the weak part on a 208 and 241 is the case. A good Morse chain seems to last through quite a lot. I've seen Ford pull truck cases where they were all hairline cracked... and they were pushing 1000hp.
    If I were really into the whole "doubler" or "super low range" thing I'd probably go SM465/drive's side NP241/divorced NP205 route. You'd have a very low range, the ability to run a pump off the 241, and the durability of all of them.
  9. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Here are some numbers for strength. These are from a recent issue of 4WOR.
    cross sectional thickness
    low-range side of the intermediate gear.
    ------------------- tooth length----tooth thickness----tooth shear area
    Dana 300 ------- 0.625 -------------- 0.310 -------------- 0.1938
    D300 w/LoMax- 0.625 -------------- 0.480 -------------- 0.300
    Atlas II ---------- 0.910 -------------- 0.275 -------------- 0.250
    NP205 ----------- 1.378 -------------- 0.333 -------------- 0.459
    LoMax is the 4 to 1 kit for the dana 300. The design of the 300 and 205 are simialr, but the size of the 205 gears is what makes it so strong. The 300 would be loosely comparable to an NP241 in a fullsize as far a dependable torque strength is concerned.
  10. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    az-k5,
    Nice data.... that really answers the ? there.
    Mike,
    I would not put a D300 under a Blazer.... I don't think it would last.
    Go Atlas (maybe even be borderline - depending on who you ask /forums/images/graemlins/ignore.gif) or 203/205 Doubler....
    Marv
