New Transfercase
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Donovan, Feb 12, 2002.
  1. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    After about 10 years of wanting to build a transfercase I am going to finally build one. What I want to know is, would people buy this transfercase if I built it. The reason I am asking is I have to get a pattern made for the aluminum casting and it is not cheap but it would be mine and I can have new cases cast anytime. So here are the spec on it. First the low range would be between 2.60 to 2.80 to 1 and then a 1 to 1 high range. As a option you could get another gear box with the same 2.60 to 2.80 to 1 in it. So you could have 6.76 to 1 and a 2.6 to 1 and then a 1 to 1. I am looking a pricing it around $1800-2000 for the 2 speed and about $2600-2800 for the 3 speed setup. This transfercase would be the strenght of a 205 but with a little lower range in it. The weight I am look at is around 120 pounds for the 2 speed and about 150 for the 3 speed setup. Let me know what you guys think of this. Thanks
    Donovan
    <a target="_blank" href=http://www.rustbucket.rockcrawler.com>www.rustbucket.rockcrawler.com</a>
    Got Leafs??
  2. J.R.
    J.R. Guest
    do you have one built now?? just wondering how its holding up. age,miles,abuse, etc..?? it sounds good,
    BIG BLOCK MAN
    "MORE POWER"!!
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    perhaps you could list advantages of your design over 205 etc
    formerly 77chev
    still a jerk though
  4. Ruthiford
    Ruthiford Registered Member
    Jun 25, 2001
    37
    Denver Co
    why not just cast the 205 case in aluminum and then do the 203 just add extra material in all the right places then we could reuse the gears we have and save weight (and save you some work).Please dont take this the wrong way its a great idea But you can allready get 3to1 gears for the 203 I think that if you came up with an up dated (lighter)case for both the 203 and the 205 you would have a money maker.
  5. Donovan
    524
    Arvada, CO
    Well I can't list all of the advantages because I don't want to give away all of my designs but here is some. The rear output will be larger than the stock 205 which is 32 spline 1.375" OD. The front output will still be 32 spline. The length of the 2 speed with adapter will be the same lenght as the adapter and a 205 for a TH400 setup. This should be shorter than a th350 adapter to 205 setup. The 3 speed will be the same lenght as the 203. Also you should be able to clock the transfercase up so that you will have a flat belly pan with no tunnel or floor pan modifications. I have been machining the case out of billet stock and it has taken a long time to do. I should have the first one done in 6-8 weeks and I will be testing it in my Jimmy behind a 500 Caddy engine this Summer and I hope to have a couple ready for the BlazerBash in August.
    Donovan
    Got Leafs??
  6. Ruthiford
    Jun 25, 2001
    37
    Denver Co
    that sounds more interesting
  7. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    cool, but why aluminum? thenid need a skid plate. [​IMG] i am quite jealous that you're that far into production, i always wanted to engineer something really wicked, but dont have the means to
    beligerence doesn't justify intelligence.
    <font color=blue>wheelers hate posers.</font color=blue>
    <font color=red>79k15/400/700r4/205/38.5</font color=red>
  8. Donovan
    524
    Arvada, CO
    Nobody else interested in a New Transfercase. I thought people would be more interested then this on it. I guess I will post it to the Pirate board and see if I get anymore repond to it and if not I guess I will not build them.
    Donovan
    Got Leafs??
  9. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    Just build one for yourself and then show some people what you have. Sort of the, if you build it they will come principle. Sounds good to me except maybe kind of pricy. Good luck
    When all else fails... Check the blinker fluid.
    78 K-5
  10. Overkill
    Overkill 1/2 ton status
    Jan 15, 2002
    284
    Orlando, Florida
    I think the price may be a major factor, since one could put double 205's in for a lot cheaper and have easy access to spare parts etc. Just my opinion.
    Jamie
    Pics at <a target="_blank" href=http://community.webshots.com/user/jlblmkh>http://community.webshots.com/user/jlblmkh</a>
    (Formerly heaj1)
    Swimmin like a rock, slingin like a stock, but not for long.
  11. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Jeez...!
    Sign my a$$ up...! 120 lbs?! 2 low ranges?!? length of a 203 ?!?
    Ship it...!!
    Marv
  12. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    Sounds good to me. If I could replace my np205 with a double case about the same length it would be awesome. Post this over on Pirate and see what happens.
    I am interested.
    Email me some info if you have any more you did not post.
    Depdog
    <font color=blue>Weenie K5, little mods' Small Tires!</font color=blue>
    <a target="_blank" href=http://depdogsk5.coloradok5.com>depdogsk5.coloradok5.com</a>
