New Ujoints often?
Discussion in 'The Garage' started by stockk5, Jun 21, 2005.
  1. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    hey i was wondering what is wrong with my truck or maybe its just a normal lifted truck deal. My k5 has a 4" lift, i lowere the tcase w/ the spacers that are already on the tcase cross member but about ever 3000miles i have to changed out my rear ujoints, the one that gets completely destroyed is the one that connects the driveshaft to the pumpkin. The one that connects to the yoke is usually ok but i change it anyways. Is this normal? I plan on going to a 6" lift soon so what will i have to do to not have to change them every 3000miles?
  2. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Are you greasing the new joints when you put them in? Otherwise I would say your angles must be way off and you need to shime the rear axle. With only a 4" lift you should not have too many u-joint problems.
  3. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    tons of grease when i put them in. Where can i get shims.. how do they go in? please direct me!
  4. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    Shims go between the spring pack and the perch on the axle, they are cut at an angle to rotate your rear axle up towards the transfer case to reduce driveline angle. any shop that sells lifts sould be able to help you.
  5. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    what kind of lift? blocks or springs? from my experience with 4" in the rear, the best way is a shackle flip as it pivots the pinion angle up more. i can get you pics later today of it, or someone else has some i'm sure.
  6. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    i have 4" blocks in the rear
  7. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Are they square cut or tapered?
  8. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    very very slightly tapered i believe. they are from a rough country kit.
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Best thing to do then is to get yourself and angle finder and find out the angle from the tcase to the driveline and the angle from the pumpkin to the driveline. The 2 angles ideally don't want to be more than 2 degrees from each other.
  10. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    i had a similar problem and i went to a custom (i think its was 3*) block no probs in bout 5,000mi so far (knock on wood). i took it to a few places for estament and most expensive one i got was $100 for measure, custom cut, and install. otherwise prettymuch everyone has them. i have a spare 4.5* or they cost $12 brand new from ORD
  11. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Me 2
    Shim kit???? I need about a 25 degree shim...I just did a tuff country 4" shackle flip and 1" zreo rate on my 91 K5 and now, at the axle, there is almost no degree at all. It looks straight. The angle at the tcase looks about right though. The rear driveshaft now sits about an inch farther out of the tcase. I now have horrible vibration as soon as I start moving. I'm too scared to get over 20 mph now. I'm going to drop the tcase 1" and see if it is better or worse. ORD suggester I buy a Tom woods driveshaft ((BIG BUCKS)). I wish they had suggested I go with a spring lift so I wouldn't have this problem. I can't imagine how many ujoints I'm going to go through.
  12. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    drop the tcase 1inch it should solve all ur problems
  13. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    You sound confident
    That is great to hear. I'll do it tomorrow night.
    Thanks much. :D :D :D :D :D
  14. victory65
    victory65 Registered Member
    Feb 1, 2003
    14
    Newberry, Mi.
    How much cash do you have for the upcoming 6" lift?
    I just finished my 72 K-5 with 6" easy rides up front with ORD heavy duty greasable shackles and 4" easy rides with ORD's 4" rear shackle flip for the rear. The shackle flip for my 6" lift provided the necessay ammount of angle correction for the pinion yoke. With a 6" lift on my K-5 I also needed to get a new rear driveshaft from high angle driveline with a cv joint. I also upgraded to a heavy duty shaft set up for Spicer 1350 u-joints and custom pinion and t-case yokes to accept the larger joints. The driveshaft and yokes ran about $600. and have worked great so far with about 500 miles on them with no vibration.
    On a side note, if there is any slop in your pinion yoke where the u-joint caps ride, this will lead to premature failure. Also, if your pinion bearing is worn it can do the same.
    Good luck and have fun.
