New version of Calculator almost ready.
Discussion in 'The Garage' started by Triaged, Dec 4, 2004.
  1. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    New version of Calculator almost ready....Edit: READY NOW
    Update:
    I got almost all of it working. About the only thing I would like to do on this version is to add in a calculation of the "anti-squat" CG (vehicle - rear axle CG) insted of just the vehicle CG. I'm going to have to do some hand calc's to make sure I remember how to do that /forums/images/graemlins/confused.gif
    Anyways check to make sure the macro's work in the new "TRAVEL" section and make sure I didn't screw anything up that I didn't notice. I did it in ExcelXP but saved it as a 5.0/97 file. Someone see if it works on the older stuff.
    I also made it so you can add your own materials to the list...they just have to be in alphabetical order or it won't work.
    Once I get that all finished up I think it will have enough changes to be called v3.0!!!
    http://home.earthlink.net/~triaged/Files/4BarLinkV2.1.zip
    Edit:
    I also changed the name to be more "proper".
  2. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Ok I finished it up and called it 3.0
    It will now tell you the sprung mass CG and the "anti-squat CG" (vehicle CG - rear axle CG) if you give it vehicle CG, front/rear sprung mass, and tire radius. It took less time then I though...gota love the find/replace comand.
    I also made a small text message to go along with it.
    Most of the dicussion for this is here and here
    http://home.earthlink.net/~triaged/Files/4BarLinkV3.0.zip
    Edit:
    If you do have any questions ask them in this thread or on pirate because I am not a member of this site right now.
  3. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Re: New version of Calculator almost ready....Edit: READY NOW
    Wow! The new version is really trick Dan. I am going to start playing with it and probably put it to use in the spring.
