new vibration after sitting a while - help!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by creampuff90k5, Jan 16, 2003.
  1. creampuff90k5
    creampuff90k5 1/2 ton status
    Feb 15, 2002
    142
    New Jersey
    I know this vibration issue has been done to death, but I tried a search already and couldn;t find any help...
    See, the truck had been sitting in my driveway unused for about four or five months due to work and travel constraints. Now that I am starting to use it again, I notice a strange vibration that was not occuring before. It happens under light load from about 35 all the way through 65 mph. In fact, it even vibrates a little just coasting down from say 45 to 30mph. No vibration present under heavy acceleration.
    So my question is: What would cause a vibration to develop from just sitting?? I spend a few hours underneath checking on the usual suspects like motor & tranny mounts, U-joints, frozen hubs, bearing, etc... but everything was fine and tight. Like I said, there was NO vibration at all before I stopped driving the truck for a few months. What could cause this?
  2. TED
    TED Registered Member
    Nov 27, 2002
    81
    San Jose, CA
    I once let a truck sit a long time and the tires got flat spots on them. (They were not round anymore). It felt like a vibration and was caused by sitting in one place too long.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I agree on the flat spot in tires theory but if it's not then it could be some frozen U joints.
  4. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    Is the vibration felt in the steering wheel or the
    seat of your pants?
    If it's felt in the steering wheel you probaly have a flat
    spot in your tire try rotate ft to rear and road test agine.
    If felt in the seat of your pants possible u-joint.
    Hope this helps,
    Bo
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  5. creampuff90k5
    Feb 15, 2002
    142
    New Jersey
    Thanks for your help so far. The flat spot on the tire(s) thing was my very first thought, but I've been driving the truck every day for almost a week and the vibration hasn't gone away, so I kind of ruled out the tires. They would have regained their original shape by now, right?
    The vibration is not coming fron the front end. So, that leaves the U-joints, I guess? The U-joints on the rear driveshaft are only about a year old. Is there anything I can do short of full replacement to break 'em loose?
  6. Sidepipes
    Sidepipes 1/2 ton status
    Nov 9, 2002
    139
    St. Thomas, Ontario, Canada
    If you have flat spoted the tire, it will never fully be round again.
    I had a frozen ujoint in my old truck and it acted up much the same as you are describing. I found out one cup was frozen. I'd replace them if they are frozen but you might try and grease them and they might break loose. But remember if that is the problem that the forzen joint has induced an extreme amount of heat into that ujoint and probably caused some major needle bearing wear.
