New Vibrations & Sounds
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by LA91Blazer, Sep 21, 2001.
  1. LA91Blazer
    LA91Blazer Registered Member
    Mar 4, 2001
    90
    Hi all !
    I recently added a 6" lift, with alot of ORD stuff to my rig. She ran great for about 3 months. Now she is vibrating when I accelerate. What is this symptomatic of?
    She is also making a loud CLANG sounf from the tranny/xfer case when shifting from forward to reverse or vice versa. What is this symptomatic of? It will also make this sound when driving on the freeway and going from coasting to accelerating.
    Any Ideas?
    My guess is the vibration might be my uni joints are starting to go.
    I have no idea about the noise.
    thanks for the help
    I'll get pics up when my membership goes through.
    BlazingWolf
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Heres a good check. With the engine off, put your truck in neutral with the parking brake on or the wheels blocked. Roll under the truck and rotate by hand the real axle and look look over the cv joints while your roll it back and forth, up and down. If everything moves together tight but it rotates quite a bit, you might have excessive wear in the diff, most likely the case if your running stock axles and big tires. Given the vibration though I'd look at the pinion bearing, the transfer case rear bearing (might show leakage) and your cv joints as the cause. The cv joints should be tight with no play at all, sometimes lightly worn ones wont be exposed by a hand rotation. Do the same to the front. If everything looks ok, try getting someone to load up the truck with the brakes on shifting into drive and reverse while you watch the under carriage from a safe place, this might expose the problem too.
    What, Me Worry?
  3. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Did ya drop your t-case when you lifted it? If not that could be causing a vibe from the drive shaft angles....
    GOD BLESS AMERICA!!!
    <>< PSALMS 23 ><>
    <a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>Steph's Webpage</a>
  4. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I just realized you said it drove fine for 3 months.... I'd check u-joints... my rear drive shaft had a bad one and that was the problem...
    &lt;&gt;&lt; PSALMS 23 &gt;&lt;&gt;
  5. LA91Blazer
    Mar 4, 2001
    90
    YUP DROPPED TH T CASE 1 1/2 INCHES...
    BlazingWolf
  6. LA91Blazer
    Mar 4, 2001
    90
    I'm gonna try Borrago's recomendation tomorrow and see what I find...
    BlazingWolf
  7. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    What CV joints are you refering to in the rear? Are you talking about the "U" joints? If so, that is a good way to check. Just push up and doen on the driveshaft at the rear end side and see if there is any play. If so you just need to replace the U-joints. Problem most likey lies in that your previous U-joints were worn adn when you added the increased angles due to the lift, the u-joints they wore out completely.
    Replace them and you'll be happy.
    "you know... the guy with the BAD A$$ spring perches!!![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  8. LA91Blazer
    Mar 4, 2001
    90
    Thanks Guys (and Gals!) for the advice, I'll check tomorrow and let u know...
    BlazingWolf
