NEW! Weld on Disk Caliper Brackets.....from RuffStuff!
Discussion in 'Vendor Forum' started by Gravel Maker, May 27, 2006.
  1. Gravel Maker
    Gravel Maker 1/2 ton status Vendor
    Feb 6, 2006
    2,572
    23
    Sacramento, CA
    This is a giant step up from the weld on Caliper Bracket you have all seen that is available in 3/16" only, the difference is that this one is made out of 3/8" Plate and cut for a 2.75", 3.0", or 3.25" axle tube. The caliper is the '75 Chevy 3/4 ton, it is very easy to find and it is cheap to buy. The rotor will depend on your application, since these calipers are floaters they will go on just about any vented rotor. This is the cleanest way to build an axle, cut off that old drum flange and weld on the bracket, no bolts to check on, lighter weight, easy mounting.
    And ONLY $33 a pair (before the CK510 10% discount!):o
    Just finished them, [​IMG]
  2. Gravel Maker
    Feb 6, 2006
    2,572
    23
    Sacramento, CA
    Think 10 bolt, 12 bolt, just about any axle.....
    With the 3 different axle cutout sizes you can mix em up with most every rotor available. And $33 says it all.....:eek1: (before the discount)
  3. Gravel Maker
    Feb 6, 2006
    2,572
    23
    Sacramento, CA
    We have changed the design a little......
    And now offer them in 4 axle tube sizes, 2.75", 3", 3.25", & 3.5". We have you covered on all bases.....
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Can these be used on a Ford 9"?
  5. Gravel Maker
    Feb 6, 2006
    2,572
    23
    Sacramento, CA
    They can, I would get the rotors from an F150......
    or Bronco and then set up the distance before you weld.......Buy the one smaller than the axle tube (3.125") so you have room for possible adjustment in height...
