New Welder
Discussion in 'The Tool Shed' started by walla2k5, Aug 13, 2006.
  1. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Went and picked this up the other day.
    So far I very happy with it.I don't have a bottle yet,so flux core for a while,but it seems to do a good job.:D
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    cool, good luck with it. I had one, it was a good little machine. Did my entire SAS on the S10 with it.
  3. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,131
    27
    El Paso, TEXAS
    Same one I have. I have a bottle but havent used it yet as I bought a 10lb. spool of flux. At first I hated it but i have gotten used to it and i have very little splatter.
    Cool deal--
    Dan
  4. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    I think that's the deal I'm going to get. Can't seem to beat the price.
  5. walla2k5
    Sep 5, 2004
    2,054
    Walla Walla, WA
    $ 600 at Lowes. A friend of mine works for Oxarc locally, said his cost was $ 690.Guess you can figure out where I went easy enough.
  6. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    hummm the one at home depot is 590 somthing, but it is a 175HD
    wonder what the difference is???
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i was just getting ready to ask about the Pro Mig 175.
  8. walla2k5
    Sep 5, 2004
    2,054
    Walla Walla, WA
    I looked at that one too.The difference is the 175HD is "NOT" gas ready.You need to buy an adapter(which will run you $80+) to make it work.
  9. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Mine is an HD and came with the valve/gauges and hose? I haven't bought a bottle yet, but what else will I need?
  10. walla2k5
    Sep 5, 2004
    2,054
    Walla Walla, WA
    All I know about it is what I was told, from my friend at Oxarc.It is flux core ready,but needed some sort of adapter to make it mig friendly.:confused: I've yet to get a bottle for mine too.
  11. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i dont think so , the guages look ready to go right into a bottle
    probally the same exact thing, just with a HD on it
  12. cbbr
    Jul 17, 2004
    14,681
    Yep. I looked at mine again and all I need is a bottle. The gauges and everything are good to go.
  13. walla2k5
    Sep 5, 2004
    2,054
    Walla Walla, WA
    O.k. I got the skinny on the adapter. The 175hd needs an adapter part # 664-2 to weld aluminum. The Pro-mig 175 already has that kit installed.Sorry for the confusion.:D
  14. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    what kind of input does a machine like this need? there's a 220 outlet in the garage that used to be for a dryer, will that be sufficient?
  15. walla2k5
    Sep 5, 2004
    2,054
    Walla Walla, WA
    That'll do it.Probably need to wire in a new plug or receptical though.
  16. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    yep, new receptical, if it is a 3 prong dryer youll be fine, just swap wire for wire, it is a 4 prong you will use green/bare copper, white, and black, and cap the red wire
  17. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    how big of a breaker are we lookin at? i think its got a 20a on it now, will that need to be changed?
  18. kgillyk5
    kgillyk5 1/2 ton status
    May 29, 2003
    1,830
    Fultonville, NY USA
    Dryers are 30A breaker w/ a 10/3 Gauge wire.
  19. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    talked to my dad a little about it earlier, and i forgot all about taking out the 220 outlet when we put the hot tub in.
    we did put in these two though when we got the compressor. [​IMG]
    they're both routed through a separate breaker box, and have 2- 20v breakers each. one is for the compressor, and the other is just there as a spare, although i dont know why. :dunno: will one of these work? or will it require an outlet change as well?
  20. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Yo need to look at the power requirement of your welder. My Lincoln SP175 runs off a 40Amp, 2 pole breaker. You will probably need to size up both the wire and the breaker. If the conduit runs all the way back to the panel, shouldn't bee too bad. You'll need to run #8 wire for a 40A circuit.
