New Wheels on old Axles
Discussion in 'The Garage' started by LovesDunes, May 13, 2006.
  1. LovesDunes
    LovesDunes Registered Member
    Oct 30, 2005
    48
    San Diego
    Will wheels from a newer 8 lug chevy truck have the same bolt pattern as the old 8 lug axles on my Blazer? The axles are from a 79 3/4 ton pickup.
  2. timmay
    timmay Registered Member
    Oct 24, 2004
    62
    Here
    Yes. My friend ran factory aluminum wheels from an '03 2500HD on his '78 3/4 ton axles in his '84 Blazer.
  3. sweetk30
    Nov 1, 2004
    25,540
    539
    horseheads , ny 14845
    ford was the stupid ones to change. gm and dodge still the same.
  4. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    one thing to check, and I'm not sure what GM uses on the newer ones, but some wheels are hub centric meaning centered by a machines lip on the hub and others are centered with the lug nut accorns. Might duble check that. Also make sure it will fit over the hubs in the center hole.
  5. rumbly truck
    rumbly truck 1/2 ton status
    Jul 4, 2005
    132
    utah
    I am running the factory alloy 8 lugs on my 1985 k-3500, they center up perfect on the hub. I just took them off for the summer. These came off of a 2002 duramax. Hope that helps.
  6. LovesDunes
    Oct 30, 2005
    48
    San Diego
    Thanks Guys
  7. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,229
    487
    New Hampshire
    I see a lot of people using Hummer wheels on their rigs
  8. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    :D :D :D :D
  9. Chevy305
    Jan 23, 2006
    11,229
    487
    New Hampshire
    They do look good, I must say. :cool1:
