newb wheel question
Discussion in 'The Garage' started by 87'k5boggin, Dec 26, 2006.
  1. 87'k5boggin
    87'k5boggin Registered Member
    Dec 9, 2006
    76
    pascagoula,mississippi
    Im looking at some pro comp wheels and they come in two styles: normal and hubcentric. but i do not know what hubcentric is, so what is it?:confused:
  2. 87'k5boggin
    Dec 9, 2006
    76
    i have searched for this but cant find anything!
  3. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
  4. 87'k5boggin
    Dec 9, 2006
    76
    yes that helped thanks
  5. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    We've always called them stud piloted or hub piloted, but is like what the web page says.
  6. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    Good to see another MS boy posting up, so what exactly is the advantage? Puts the weight more on the hub then the lugs? Makes it easier to put the wheel on? Did I just answer my own question or am I way off?
  7. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    hubcentric wheels suck. they come on the superduty. the wheels get seized on the hub and are a bear to get off. especially in the inner tire on a dual setup. hubcentric wheels will not work on a stud piloted setup. the wheel does not have taper built into the lugnut holes.
  8. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    1st half yes thay suck .
    2nd half no. the aftermarket have the acorn nut seats in them. only the stock ford rims have flat flange nuts with no acorn seats in them.
  9. 87'k5boggin
    Dec 9, 2006
    76
    yes i found out you dont need them they are mostley a waste of time just get the wheels with the acorn style lugnut bore on them
  10. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    they still suck.:D all the aftermarket ones I have seen at swap meets are easily identifed by the lack of taper. what would be the point of having the taper since the bolt pattern is also bigger and will only fit the superduty? not starting a fight, just asking.
  11. 71 Blazer
    71 Blazer 1/2 ton status
    Jul 16, 2005
    184
    windsor virginia
    My blazer had all 4 tires siezed to the axles due to those stupid centering hubs. i had to take a torch to the hub and heat it up, still took a 2 lbs maul to get them off. Good thing they were steel rims. I don't think the PO had rotated the tires in a little while.
