newbie 14 bolt question
Discussion in 'The Garage' started by 1982blazer, Feb 28, 2007.
  1. 1982blazer
    1982blazer 1/2 ton status
    May 11, 2006
    313
    Tyler Texas
    Ok so today i whent to pull the drume of one side of my 14 bolt, i pulled the axle shaft, took off the first lock washer, removed the the washer in the middle, then i removed the last lock washer. After removing that stuff i tried to slide the drum off but i couldn't, is that all i have to remove to get the drum off?:D
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
    Should be. E-brake's not on right?
  3. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Its probably the brake shoes. The shoes can whair inot the drum becasue they self adjust. So you have to unadjust them. let me know if you need to know how to do that.
  4. 1982blazer
    May 11, 2006
    313
    Tyler Texas
    That was kinda what i was thinking, that side wont even turn i think it is only one shoe becuase the bottom half of the drum will move just a little bit. and no i dont know how to unadjust them.
  5. 1982blazer
    May 11, 2006
    313
    Tyler Texas
    No the axle is not even in a truck right now i bought it to swap in my k5.
  6. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Ok here goes. This is what the inside looks like,
    This is what adjusts the shoes. If you look at it all closely enough, You can see that the series of springs and levers ride on this "stared" looking piece that has threads in it. So enevry time that lever moves, it spins the star which unthreads a litle bit moving the shoes closer to the drum. This is what you need to unadjust.
    To do that go to the back side of the drum
    You need to get into the elongated slot at the bottom of the drum, the one i have marked with the penny here.
    If you look through that slot you will see the star piece.
    You must spin the stared pice back in using a screw driver, trying to basicly accomplish the oppisite of what the self adjust lever does.
    To do this start with the tip of the screw driver at the top
    then spin the star moving the tip of the screw driver from top to bottom. and repete several times
    and that shuld do it!
  7. 1982blazer
    May 11, 2006
    313
    Tyler Texas
    Thanks alot man i will get it done tomarow.
  8. K5Greek
    K5Greek 1/2 ton status
    Nov 25, 2005
    2,054
    Vineland, NJ
    when i did mine the slot for the adjuster was on the front of the drum.. not on the backing plate
  9. jamber2541
    jamber2541 1/2 ton status
    Apr 10, 2006
    424
    e.p. texas
  10. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Can you post up a few more pics of the back-and-forth adjustment?
    I'm still confused a little.....
    :haha:
  11. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    If you scroll through it real fast, it looks like a movie...:haha:
  12. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    ya ya ya ok wise guy! just illistrating a point, you know.
