Newbie 88 Blaze question
Discussion in 'The Garage' started by thekiffer, Apr 28, 2006.
  1. thekiffer
    thekiffer Registered Member
    Aug 30, 2005
    24
    Englewood,co
    Ok, I am confused. I have a 1988 Blazer. Can I do the 52/56" rear leaf to front swap? How much lift does that swap give you with stock shackles or do you have to replace the shackles? Do you have to change your steering from stock right away with this swap? Sorry, I know just a newbie to Blazers.
  2. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Yes, you can do the 52" swap. Depending on the springs, you'll get approximately 4" of lift, and super-duper flex. You'll definitely need longer shackles, and you'll need to either relocate the front spring hangers in front of the core support bodymount brackets, or relocate the rear shackle hangers to the rear some. You'll definitely need to do a crossover steering swap. You'll also need extended front brake lines and a longer-travel front driveshaft.
    I gave a quick summary - here's a thread that spells out or links to all the gory details.
    52" spring swap thread
  3. thekiffer
    Aug 30, 2005
    24
    Englewood,co
    Thanks, a ton I read the article I just keep seeing products with 81-87 and don't really know what is different about the 88 from the 88. Bye the bye Semper Fi, Devil
  4. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    in blazers and burbs, those years go up to 91'. the pickups (non 3+3's) only go to 87' for the straight axle front.
  5. thekiffer
    Aug 30, 2005
    24
    Englewood,co
    ah, gotch ya. So as far as the frame goes on a Blazer not much difference from the 87 to the 88?
  6. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    I'm a little confused :doah:. I put 52in springs on the front and rear of my K10, and I didn't have to modify anything. My frame is totally stock so what is the deal?
  7. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    are you sure they were 52's? how is your shackle angle if they were? and how long are your shackles? and your k10 had 52's to begin with in the rear.
    and with the blazers, 87 and 88 are the "same". there could be slight differences that dont mean anything. but they are the same "generation" so they are basically identical.
  8. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    Everything lines up perfectly, the shackle angle hasn't changed. I did order Tuff Country 52in springs. They have 3 leaves verses the 5 leaves of my old front springs.
  9. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    You didnt move the front mount or anything??????
  10. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    No, I just installed the springs and everything fits. :dunno: :screwy:
  11. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,603
    555
    Wasilla AK,
    pics???
  12. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    Sure, I'll take them tomorrow
  13. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    they may be 52" long with the arch included. but surely they are not replacements for 52" springs. if you didnt move your front mount, then your axle would be 2" farther back because of the center pin. i would know, i just put my 52"s in today infact.
