Newbie Faux Pas
Discussion in 'The Garage' started by Lowtode, Sep 24, 2003.
  1. Lowtode
    Lowtode Registered Member
    Dec 23, 2002
    14
    Norman, OK
    I have reading the CK5 forums for a while and have never posted anything since I usually figured out my problem. Well now that time is over, I have a question. I out a 4" lift on my Blazer, easy enough. But I'm not happy. I don't like the way the back end looks. It resembles my 120-year-old neighbor, pretty saggy. My problem is, if I want to put 6" springs in the rear, what will I have to do about the emergency cable. I need options though, for redneck to monster truck ($$$)
  2. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I don't believe anything needs done with the e-brake cable. And assuming you got extended length brake lines there should be no more mods needed to go from 4" rear springs to 6"
  3. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Hey man welcome to the board there are several of us OKC area members here, we get together and wheel some. As for your question, you should not have to do anything to your e-brake, worse case scenario is you will have to adjust it out a little bit at the adjuster to compensate out for the extra lift. If you want to get together and do some wheeling give me or skulznbonz (John) a shout. /forums/images/graemlins/thumb.gif
    Krennen /forums/images/graemlins/thumb.gif
  4. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    If the rear is lifted w/ anything other than blocks skip the 6" rear spring and put a 1 1/2" block in the back.
  5. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    if your stock springs are that saggy, its probably best to replace them with a good quality aftermarket spring. If they seem to be servicable and you want to keep them, I recommend using an echobit shackle flip (generally 5-5.5" of lift AFAIK) to cure your saggy butt.
    j
  6. Lowtode
    Dec 23, 2002
    14
    Norman, OK
    Well, before I got the lift I did get some new stock springs from LMC, so I paid a pretty penny for them. So when I got the lift I went with blocks in the rear, it just seems that the e-brake rides really close to springs. But if I stuck 6" springs on in place of the stock springs and 5.5" blocks then that will solve any sag problems. But does the e-brake go under or over the spring?
