Newbie ? - Hood alignment
Discussion in 'The Garage' started by odoa3, Sep 1, 2004.
  1. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    Pulled the hood off when I pulled the engine. Now, I cannot get it to align. The drivers side rear sticks up about two inches. I have loosened, adjusted, and retightened for hours- and I still can't get that corner down. Any advise? What am I missing? /forums/images/graemlins/1zhelp.gif
  2. js4x4
    js4x4 1/2 ton status
    Jul 17, 2004
    798
    San Diego, CA
    does it budge at all if you press on it? (the area thats pokin up) When you removed the hood, which bolts did you take out? Just the ones connecting the hood to the arms? the ones in the firewall? both? Did you make marks on any of the connection plates you unbolted? BFH will fix it for sure, but it won't be so pretty...I dunno how to advise you w/o knowing more specifically what you did.
  3. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    I just took out the two bolts on both sides that connect the arms to the hood. The hood does push down. Stupidly, I did not scribe a line around where it was- won't make that mistake again. /forums/images/graemlins/rolleyes.gif
    There are stops or posts with rubber bushings or spacers on the top on the firewall- do those go inside the holes in the back of the hood to help hold the hood down? If so, I do not think the hood is grabing it on the one side. The hood seems to be lined up with the fenders and it latches with a slam. Talk about frustrating!
  4. namkrow
    namkrow 1/2 ton status
    Apr 25, 2004
    166
    So Cal
    if you have the old style hood (the one that almost touches the windshield), you may have a bad hinge.
    They get worn out and don't go down so easily.
    If it's the newer style hood (with the cowl between the hood and the windshield...you got me...)
    -T
