Newbie needs help with NP205
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 96chevy, Sep 1, 2003.
  1. 96chevy
    96chevy Registered Member
    Aug 19, 2002
    14
    Smyrna, TN
    I have a '80K5 w/ an automatic TH350 and a NP205. I went out to check the fluid level and when I undid the top plug on the tfer case tranny fluid came pooring out, about 2/3 quart. I thought that 205's used gear oil. And does the tfer case have to be warmed up before you can check the fluid?
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> In an 80 there should be gear oil in it, but in later years they switched to tranny fluid or motor oil, if memory serves. I'd put gear oil back into it, but it will probably be fine. The thing would probably live if you put vegetable oil in it, they are pretty durable units and seem to be tolerant of just about any kind of lube. </font>
  3. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Maybe the tranny is leaking out the back filling the t-case ,sounds like it was way overfull.
  4. NerdBoy
    NerdBoy 1/2 ton status
    Dec 24, 2002
    429
    Southern Illinois
    I had a similar problem with my truck. I have a different drive train, but I think the setup is similar (I have a 700R4 and 208 TCase). I found that the seals on the input shaft on the TCase went out and I had to drop the case and replace the seals.
  5. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    when i was running a 350/205 combo it would do that once a year. the adapter was cracked on top &amp; it would not let the adapter sleeve ride on the seals correctly. the tranny would dump its fluid into the 205
  6. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    Yea i would say a bad seal. By the way transfer cases with gear drive get gear oil. Chain driven cases get ATF.
  7. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    203's get 10w30
  8. bigblock44k5
    Jun 8, 2003
    396
    Hurlburt Field, FL
    sorry, didnt think about that. let me rephrase, chain drives get light weight oil, gear drives get gear fluid. /forums/images/graemlins/thumb.gif
