newbie needs help
Discussion in 'Audio' started by 96chevy, Mar 11, 2003.
  1. 96chevy
    96chevy Registered Member
    Aug 19, 2002
    14
    Smyrna, TN
    i was just wondering how in the heck do you get the factory radio out? I don't want to cut the dash because I'm looking at the replacement from LMC. I know this is a dumb question, but I really need the help.
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    On most newer vechiles the trim just snaps in place. Try prying up gently with a small screw driver. Ones that's off, you'll see the bolts holding the radio in place.
  3. 96chevy
    Aug 19, 2002
    14
    Smyrna, TN
    I guess I should have explained myself better. The Blazer is a 1980 model, not the newer ones. I removed the instrument panel cover, dash pad, and the bolts on the front of the radio. My problem is where do you pull it out from? /forums/images/graemlins/1zhelp.gif
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    On my old 76, after you remove the nuts on the shafts, push it back and pull it out from under the dash, may or may not have strap/bracket on back, so you'll need to get up under there with a flash light. To install mordern stereo in factory location, hole in dash must be cut.
  5. Dale fan
    Dale fan 1/2 ton status
    Dec 5, 2002
    167
    Arkansas
    Z3Pr covered it pretty good. Pull the instrument trim cover from the guages and the nuts from the shafts that are underneath the knobs. The rear strap bolt of the radio if it's used and one important piece on those shaft radios is the air vent tube that runs over to the driver side air vent by the door. There is one screw in the metal dash below the steering column for it.When undone, pull it to the left to unhook it from the air distribution box and then to the right and down. That will allow you to pull the radio out from behind the dash.
  6. Strahan
    Strahan 1/2 ton status
    Dec 4, 2001
    251
    Yoe, PA
    Unless your goal is to keep the truck original you may want to consider finding a reputable custom shop that will cut the dash so you can install a DIN unit. Sticking with shaft limits the amount of quality headunits you can get. You could alternatively mount it somewhere else, like in the center console. Personally I'm gonna have a local shop just cut the dash. If the installer is competent you won't be able to tell it's not factory. Finding a competent installer is the only hurdle to leap /forums/images/graemlins/rotfl.gif
