Newbie NP 203 Questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 96texasz, Dec 24, 2006.
  1. 96texasz
    96texasz Registered Member
    Nov 13, 2006
    28
    Wichita Falls, TX
    my new blazer has the np 203 and the guy i bought it from said that it is all time 4wd is this true? I stuck it in to 4lo yesterday and when i tried to put the case back into drive it stuck in neutral and took forever to get back in. I called the guy and he said it hadn't been in 4wd in over a year so did i just need to bust it loose or does this sound like a linkage problem? Also it would pop out of 4lo sometimes too
  2. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
  3. 96texasz
    Nov 13, 2006
    28
    Wichita Falls, TX
    thanks
  4. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Your welcome, if you have any more questions just ask and someone will try and help you.
  5. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    One more thing, once the 203 shifter dries out it doesn't move very well. Try spraying some lubricant up into the shifter. Stay away from lithium grease. It drys out after some time and leaves back at square one.
