newbie q's-465 related
Discussion in 'The Garage' started by jones, Apr 7, 2005.
  1. jones
    jones 1/2 ton status
    May 17, 2004
    379
    IONIA,MI USA
    where is the fill hole located?i just read another post about filing through the top of the shifter!?that can be done?if so,how?thanks in advance.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    pull the shifter out and pour the fluid on down it. It is a lot easier than the usual setup. On the side of the transmission is a fill plug up above one of the PTO covers. Its a pain cause its up near the body so you can't tilt a bottle for crap.
  3. mtrdrms
    mtrdrms 1/2 ton status
    Mar 14, 2005
    312
    Torrington, CT
    the fill is on the drvers side above pto plate. i dont know if you can fill through the shifter but i dont see why you couldnt.
  4. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I do it all the time, the only way to go.
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yep, the fill hole is on the driver side about half way up. i pull the fill plug out and dump the gear oil in the shifter hole till it runs out of the hole. it takes exactly 1 gallon if your wondering :waytogo:
  6. jones
    May 17, 2004
    379
    IONIA,MI USA
    so how do i pull the shifter out? i've never really looked at it.does it bolt to the top of the case?thanks.my trans.needs fluid but i've put it off for lack of know how.
  7. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    there is the metal dome where it enters the top of the tranny. push that down and turn it counter clockwise, then you can remove the shifter. :waytogo:
    btw, i seen you sunday, you were turning onto m66 south from tuttle road. i was with my buddy in his black k10.
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    its real easy to pull shifter out, alot easier than pulling out fill plug
    this is how i fill my 465's also
    youl need a large pair of pliers to grip and push down and turn the sheetmetal dome thing counterclockwise- it sits on two roll pins in the shifter casting top of the trans case
    its real easy once youve done it once youll always do it this way
