Newbie question
Discussion in 'The Garage' started by big94gmc, Aug 6, 2006.
  1. big94gmc
    big94gmc 1/2 ton status
    Sep 1, 2004
    3,651
    No VA.
    Tires.... What's the difference between radial and bias? What're the pros and cons of each?
  2. big94gmc
    Sep 1, 2004
    3,651
    No VA.
    No replies overnight??? Stunning!:eek1:
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ****in noob;)
    i tried askin a question like this a while ago, and didnt get many responses....i guess most people just run bias and dont care bout radials. i think radials are easier to balance, but dont quote me on that.
    ive got 39.5 bias iroks on the k5 that arent balanced and i drove them 280miles on the highway going 75mph and they rode pretty smooth.
  4. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    Check out here. Just keep in mind though, they're talking about street tires.
  5. big94gmc
    Sep 1, 2004
    3,651
    No VA.
    Thanks for the link, ARAMP1. Good info, but I'm asking this question to make a tire decision for an offroad only rig (need to answer to be geared towards our community, ya know....).
  6. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    Bias are more aggressive, clean out better, and louder. Radials ride smoother and have better wear properties on the pavement. Radial TSL's have thinner sidewalls than the bias TSL's.
  7. big94gmc
    Sep 1, 2004
    3,651
    No VA.
    TTT.... Any insight?
  8. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    It has to do with how the belts are put in relation to the rotation of the tire. Radials have the belts "radially" in the tire which means they are in the same general rotation as the tire (they are actually at 90 deg to each other but generally around the circumference of the tire), Bias ply are perpendicular to the rotation of the tire. This causes the tire to have less sidewall support therefore the need for a thicker sidewall. Bias also will flat spot but is generally not a concern for an offroad only rig. I intend to run bias ply tires on my rig as some of the larger sizes only come in bias and they are usually cheaper than radials of the same size.
    This is how I understand it if I am wrong please inform me so I can be edjucated:D
    Ira
