Newbie questions from an "old timer"
Discussion in 'The Garage' started by laketex, Jun 20, 2002.
  1. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Newbie questions from an \"old timer\"
    Dont really have the time to search and I thought I'd throw a couple easy questions out there.
    First, crossover steering. Any links to premade kits or ideas on custom hysteer that could be fabbed up in a couple of evenings? I've got the tools, just not much of the understanding of how it all works. Any links? The deal is I've got a big 4x4 run in about 8 days and my current steering box is in need of a rebuild. I hate it anyway, so am looking for something a little beefier and with full range of motion on a budget. Any ideas?
    Also, does anyone have a source for those rollcage bushings for the tie in to the frame mounts? Thanks in advance.
    Bryan
  2. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    Re: Newbie questions from an \"old timer\"
    1987-1996 Jeep Wrangler leaf spring bushings fit inside 1 1/2" .120 wall tubing. Energy suspension part # 2.2107. Best I can remember, you get enough bushings in one kit to make 4 supports, they also come with the sleeves for the bolts. The kit also comes with a few larger bushings, but I don't know what they fit. The kit was around $50 bucks. Or you can use these pre made ones.
    BIGJ
  3. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    have you tried looking at the stuff on the ORD site? or west texas offroad? I know WTOR has the ram setup, but don't know about the crossover stuff.
    You GOTTA make this run!
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    These guys sell all kinds of neat little brackets and such for fabricating the parts to tie the roll cage into the frame. http://www.aa-mfg.com/
    Click on the Online Parts Catalog link. /forums/images/icons/cool.gif
  5. laketex
    6,220
    North Texas
    Thanks BigJ...I just ordered 4 of those from ORD!
  6. laketex
    6,220
    North Texas
    Harry, they didn't have exactly what i wanted, although I did bookmark that page. They had a lot of cool fab parts for sure!
  7. laketex
    6,220
    North Texas
    yeah i'm not ready for hydraulic, all I really want is basic crossover to give me lock to lock turns. I figured since my steering box is on the blink anyways and screaming, I'd just get a pass side box and set the links if I can do it in time.
  8. laketex
    6,220
    North Texas
    After looking at prices and my time frame, yall just might have to put up with my wailing steering box. Maybe it'll hold out through the weekend.
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the crossover question depends if you need a bent draglink or have the lift for a straight one.
    1.25" .219"wall tubing is near perfect for threading 7/8"-18 for the tierod ends
    which front axle?
    fast eddie from CTS just spent $$$ on a kit for a 44 or 10bolt included knuckles and everything.
    he had some tierod draglink length confusion but the shop (Tellico I think)says they will make good on it.
  10. BIGJ
    896
    Central Arkansas
    The biggest issue would be the flat top knuckle and steering arm. I have an extra straight draglink you can use if you decide to go ahead and do it. I can bring it with the tires on Saturday.
    BIGJ
  11. laketex
    6,220
    North Texas
    Yeah I'll do that. And pick your brain on how its set up when I'm there. I can buy the arms and knuckle I think. Then I'd need a 2wd box and what else?
  12. BIGJ
    896
    Central Arkansas
    You will need a dropped pitman arm, a 2wd box, and the steering arm and flat knuckle. To run tie rod over the axle, it will be more work. I got all of my stuff from ORD. They had everything at one place. Rockstomper also sells crossover steering stuff.
    The only issue you may have is the drag link hitting the engine crossmember. I made a new crossmember out of 2" .250 wall square tube. This article dep wrote has some good info on what you need too. My crossmember is very similar to his.
    BIGJ
  13. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    You could give Damon at Toybox a call, i know that hes working on a crossover kit which will move the tie rod up and reuse the draglink ends, don't know about cost but, it sounded like a pretty good kit when i heard about it.
