Newbie Questions: Voltage Gauge Problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gnihcraes, Oct 28, 2006.
  1. gnihcraes
    gnihcraes Registered Member
    Mar 1, 2006
    36
    Lakewood, CO
    Any help is appreciated!
    K30 Crew Cab, 350, 4spd.
    Recent tune up - plugs, wires, cap, rotor, module.
    Voltage Gauge is now dead?:(
    Altenator is fine, output is 14+.
    The plug on the altenator was pretty bad shape, so I installed a new one just to make sure connections were good.
    I've temporarily installed another voltage gauge, all seems good. Have driven it a lot and have no issues with lights, or voltage problems, all seems to charge well.
    Is it dumb luck that it quit working or did I do something wrong somewhere?
    Thanks, Kelly
  2. dyeager535
    26,979
    Voltage is read off the fuse panel (via the printed circuit board on the back of the cluster) so it's unlikely as easy as the wiring connector on the back if the other gauges are working properly. But it also shouldn't have anything to do with what you just did, this is of course assuming you aren't talking about an earlier ammeter.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Pure bad luck and coincidence.
    Had the same thing happen to me a couple of times.
  4. gnihcraes
    Mar 1, 2006
    36
    Lakewood, CO
    Thanks for the info. It seems to have quit working after I did the mini tune up - but I hadn't been under the dash or anything during that day. All other gauges are working well. O'well. I guess I'll look into a replacement when I get time to tear it all down and do some testing to make sure it's nothing else.
    Since I'm new here and have other questions - should I just keep posting a new topic for each item? Thanks, Kelly.
  5. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Each topic a new thread.
    that way people will know by browsing quickly what they have answers to.
    Also try searching on your questions, most questions have been asked and most likely you will find your answer in the matter of minutes without waiting for anybody. :D
