newbie questions, yes I searched
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ncbloodhound, Jan 3, 2004.
  1. ncbloodhound
    ncbloodhound 1/2 ton status
    Aug 18, 2003
    400
    Indian Trail, NC
    I am new to blazers and working on vehicles, so please bear with me... /forums/images/graemlins/tongue.gif
    1. What are idler pulleys for? Belt tension? Mine has several flat spots on it and I was wondering it could be causing the squeaking and shuddering when idling. My chilton's manual doesn't say anything about it.
    2. This one might sound stupid but...the tailgate on my blazer stops about 10 degrees from being parallel to the ground is that normal? I don't see how it could go down any further without hitting the bumper.
    Thanks!
  2. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    1. idler pullys are for shortning the length that your belt runs from one main pully to another to help control belt flop that leads to throwing a belt(belt comes off) also most idler pullies are adjustible and are used to make the belt adjustment, on most of our trucks it is the brackets that are adjustible.
    2. My tailgate comes down about level with the ground, maybe just a little bit higher at the top of the gate. Your tailgate would have to fall down a long waise for it to hit the bumper. It will only go down as far as the straps will let it. I'm sure your tailgate is fine if it comes down almost all the way to level.
  3. ncbloodhound
    Aug 18, 2003
    400
    Indian Trail, NC
    So should I replace the pully if it has flat spots all over it?
    Also, I will post a pic of my tailgate, because it just doesn't look right. Maybe the cables are too short?
  4. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    So should I replace the pully if it has flat spots all over it? Also, I will post a pic of my tailgate, because it just doesn't look right. Maybe the cables are too short?
    I have never seen a a pully with "flat spots" all over it. I bet you just need new belts. I have no idler pullies on my truck and I don't think any GM trucks do for that matter. Al we have is basically main pullies which are crank pulley, altenator, A/C, powersteering, waterpump, smog pump. I have never seen one with an idler only pulley.
    If your tailgate has never been messed with and the straps are stock than they aren't too short. If it still doesn't seem right go ahead and post a pic. Like I said my tailgate doesn't sit totally flat when fully down either.
  5. rekvehicle
    rekvehicle Registered Member
    Apr 11, 2003
    23
    Spring Hope, NC
    Your idler pulleys should be perfectly round where the belt rides.If there are flat spots the bearings in the pulley may be sticking causing wear from the belt on the pulley and premature failure of the belt.RV
  6. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    I've seen the belt tensioner pulleys get flat spots as they start to wear down. The only ones I've seen this on have been plastic. If this is the pulley you're talking about it's time for a change... I haven't seen one cause a shudder at idle but it's pretty hard to diagnose through the computer.
