Newbie with shot tilt steering
Discussion in 'The Garage' started by exrider, Jun 21, 2004.
  1. exrider
    exrider Registered Member
    Jun 5, 2004
    30
    Hey guys I've got a 78 K5 Blazer and my tilt steering is shot. I know this because I have taken it apart and am unable to tigthen up the bolts. Searching though the site I have found out more about my Blazer than I ever thought I would and one the members wrote in previous forum to replace the tilt with a standard steering column. I would like to do this or just replace the old tilt one. My question is can someone point me the right direction to get a replacement column with all the accessories on it already.
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I have rebuilt dozens of the tilt colums and the most common fiailures i see are the loose bolts and broken shift collars. Both seem like the same thing until you take it apart. I would look to see if the collar is broken. If so just reweld it like i do. It only takes me about an hour to do one from start to stop if it is out of the truck.
    When i get the time to put tilt steering in my 87 i will try to buy a broken column and just fix it up.
  3. exrider
    Jun 5, 2004
    30
    Problem with that, I am not a welder. Would I be able to just replace the shift collar? If that is the problem.
  4. readymix
    May 30, 2004
    6,706
    26
    The part that is probably broken is the main part of the column. Right behind the bolts that always come loose. If you are located anywhere near me let me know and i will fix it up for you. If not i am sure there is someone else on here that could help you out.
    Or you could just hit up the local bone yard for a new "tight" column.
  5. exrider
    Jun 5, 2004
    30
    Thanks for he offer, but I am in AZ. Looks like I will be calling the bone yard for parts then. Thanks
  6. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    See this post
    John
  7. exrider
    Jun 5, 2004
    30
    Thanks, looks I will be having some fun this weekend.
  8. diesel4me
    Jul 24, 2003
    17,537
    923
    Massachussetts
    I still havent tried to fix the sloppy tilt colum in my 79 C10,since the power brake booster is junk and I'm having a hard time finding one,plus the motor was rapping for awhile,its quiet now--but I think its waiting for me to get far from home before it blows!.After reading the post on how to fix it,I think I'm going to either let my friend who has done several do it for me--my eyes arent that good anymore,and I'm certain I'll drop something in there.If all else fails I have a non tilt colum from a 73 K10 I could throw in(I never use the "tilt" anyway)but I think that will open another can of worms,because that colum has the big splines on the end,and the 79 has the round shaft with one side squared off--here we go again! /forums/images/graemlins/doah.gif
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I've swapped out many colums. Just search you local "U-Pull it" salvage yards till you find a good one.
