Newer 10 bolt?
Discussion in 'The Garage' started by SkulzNBonz, Oct 7, 2005.
  1. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Anyone running a disc brake 10 bolt 1/2 ton axle (I assume from the post 92 trucks) on their Blazers/trucks. I have the opportunity to pick one up (well it's getting delivered tomorrow) and I'm wondering if the shock mounts and spring perches are the same. TIA
    John
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    only came with disc rears on 99 and up trucks.
    also have an 8.625 inch ring gear and i think 30 splines.
    is a good idea i think, would like to see someone try it.
    ryan
  3. SkulzNBonz
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Well, I will be attempting this tomorrow.
    John
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Is the axle from a '92 or newer truck? No, the spring perches won't line up.
  5. SkulzNBonz
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Thanks, that was the answer I was looking for. I have no idea what year the axle is from, but since it is disc brake equipped. i assume later than 92
  6. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    Skulz, read this reply again. disced rears are 99+
  7. SkulzNBonz
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Yeah, that's what I meant. Later as is newer. thanks though. I have absolutely no knowledge of the axle I'm getting, other than it is a 10 bolt w/ discs.
    John
  8. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I'm sure with a little :grind: :weld: :hack: it can be made to work without too much trouble.
    If nothing else.. just cut and grind everything off the tubes until they are clean, and weld in the spring perches and shock mounts where you need 'em. :waytogo: I doubt it will be too hard if someones willing to take the time to make it work.
  9. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Is it going in a stock application? What size tires are you going to run on it? Eventhough its a little bigger, and we havent had too many newer (99+) 10 bolts blow up, its still a 10 bolt, and if it has a gov lock, its just gonna go earlier, assuming you are going to use big tires. The discs with parking brake will be nice though.
  10. SkulzNBonz
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Not quite stock. 35" MTRs. Oh yeah, I am all too aware of the Gov bomb. For that matter, I haven't been very kind to an an open rear 10 bolt either. I'm just hopin' to get 2-3 trips out of it until the 14 bolt (I can already see the flak over that statement comin') goes in this spring. My Torquemonster 305 has already claimed 3 ten bolts, but the $$ has been right, and the fun has been had.
    John
