newer alternator
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Thumper, Sep 15, 2001.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    I have a newer 100A alternator that I am going to put into my 85. What is necessary wiring wise to put it in. Do I need some sort of connector adaptor or can I just hardwire it in? Do I need to replace the wire with a heavier guage?
    Mike
    <font color=blue>Thumper
    85 Fullsize Jimmy
    <font color=red>Aint Skeered!! </font color=red>
  2. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    I swapped a late-model "CS" alternator into my Suburban. All you should need for the wiring is a pigtail connector from Painless Wiring. There are two different kinds, depending on which alt you are using. You will find both kinds at this link on Painless' web site: community.webshots.com/user/robbrj
  3. Thumper
    1,582
    Alberta Canada
    That pigtail plug only uses 2 wires out of the 4? Whats with the other 2? Did you use them? Which ones are the necessary ones?
    Thanks,
    Mike
    85 Fullsize Jimmy
  4. 502Burban
    Jun 8, 2001
    379
    Southern California
    Not sure if I understand, but AFAIK you just need the 2 wires that are on the pigtail. If you are using the same pigtail that I am (the 30707), the red one goes to the BAT output (large stud that connects to the battery). It is really just a short jumper wire. The white wire is the alternator exciter wire that should go to your fuse box.
    Robb
    '73 GMC Suburban - 502DFI
    <a target="_blank" href=http://community.webshots.com/user/robbrj>community.webshots.com/user/robbrj</a>
