Newer model Question
Discussion in 'The Garage' started by mudbog42, Oct 19, 2006.
  1. mudbog42
    mudbog42 1/2 ton status
    Jul 16, 2006
    452
    Florida for now
    Got a question on a newer rig, my buddy's got a 98 tahoe with the 5.7 vortech and not sure what kind of tranny is in those things but when driving and get to about 45-50 MPH and let off the gas feels like you hit a bump or like a lunging forward feeling. Also does it at low RPM's but mostly when you let off the gas and it does'nt feel like a hard downshift. Checked tranny fluid after wheeling and it was good.
    Also the check engine light is for a cam sensor, not sure what that is or does but could have to do with wierd lunging??
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    that would be a 4L60E tranny, it could be your torque converter clutch engagin harder than it should, it might have something to do with the cam sensor code, you defently want to take care of the cam sensor though if it is bad
  3. mudbog42
    Jul 16, 2006
    452
    Florida for now
    Do you know what the cam sensor is, what it does, or where its at by chance?
  4. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Its the distributor. It tells the PCM when #1 is up on TDC and is used in misfire diagnosis.
    If the intake manifold gaskets were recently replaced it could just be installed wrong or out of time (the distributor).
  5. mudbog42
    Jul 16, 2006
    452
    Florida for now
    Could that be causing the weird lunging feeling from the tranny?
  6. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    I doubt it.
  7. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    it might be able to but im not 100 percent sure, it depends on how the PCM determins lock up, if it uses engine speed and the cam sensor is bad it might cause a harsh or early lock up, but this is just a guess
